shifting console springs, springclip disappeared |
JimN73 |
Nov 30 2018, 05:11 PM
Senior Member Group: Members Posts: 535 Joined: 6-October 07 From: Gig Harbor Member No.: 8,192 Region Association: Pacific Northwest |
There are two stiff springs on rods in the shift console, one just in front of the shifter and one just behind. One of the springclips on a shaft is gone and the rod backed out of the housing far enough for the spring to slip out of the housing.
Stuffing the spring back into the housing is tough. Anybody have any ideas or tips? Picture attached, #3 and 4 Thanks, |
mgphoto |
Nov 30 2018, 05:33 PM
"If there is a mistake it will find me" Group: Members Posts: 1,337 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Use Phillips screwdriver, bend spring to place open end over hole, push through the screwdriver while pushing the spring into place. Work both ends, one side shaft other screwdriver, when spring is in place, push the shaft through the hole pulling on the screwdriver, install circlip.
Seems tough but not that bad . |
mepstein |
Nov 30 2018, 06:27 PM
914-6 GT in waiting Group: Members Posts: 19,245 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Above directions but use a vice grip to hold spring and push it down and wear leather gloves and eye protection because the spring can shoot out with a lot of force.
mgphoto |
Nov 30 2018, 06:43 PM
JimN73 |
Dec 11 2018, 03:28 PM
Thanks, I tied the spring to the shifter body so it couldn't go too far. Still not fun.
rhodyguy |
Dec 11 2018, 03:47 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,066 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
You got the springs in?
mepstein |
Dec 11 2018, 05:07 PM
Once you get the technique down, its 2 minutes.
rhodyguy |
Dec 11 2018, 05:18 PM
PMs sent.
Lo-Fi Version | Time is now: 29th April 2024 - 12:14 PM |
