shifting console springs, springclip disappeared |
JimN73 |
Nov 30 2018, 05:11 PM
Senior Member Group: Members Posts: 535 Joined: 6-October 07 From: Gig Harbor Member No.: 8,192 Region Association: Pacific Northwest |
There are two stiff springs on rods in the shift console, one just in front of the shifter and one just behind. One of the springclips on a shaft is gone and the rod backed out of the housing far enough for the spring to slip out of the housing.
Stuffing the spring back into the housing is tough. Anybody have any ideas or tips? Picture attached, #3 and 4 Thanks, |
mgphoto |
Nov 30 2018, 05:33 PM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Use Phillips screwdriver, bend spring to place open end over hole, push through the screwdriver while pushing the spring into place. Work both ends, one side shaft other screwdriver, when spring is in place, push the shaft through the hole pulling on the screwdriver, install circlip.
Seems tough but not that bad . |
Lo-Fi Version | Time is now: 16th May 2024 - 12:01 AM |
