Seal for bonnet and rear window, How do you remove it? |
DickSteinkamp |
Nov 30 2018, 05:43 PM
Senior Member Group: Members Posts: 500 Joined: 27-February 17 From: Bellingham, WA Member No.: 20,876 Region Association: None |
(IMG:http://www.914world.com/bbs2/uploads_offsite/farm5.staticflickr.com-20876-1543621428.1.jpg)
#15 in the illustration PN 914 512 319 10 Mine is the original with the metal channel. Seems like it should just gently pry off, but it doesn't. Thanks |
dr914@autoatlanta.com |
Nov 30 2018, 06:01 PM
914 Guru Group: Members Posts: 7,866 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
grab with vice grips and pull side ways and peal it off. Sometimes it rusts on so you will have to keep pealing little bits of it
(IMG:http://www.914world.com/bbs2/uploads_offsite/farm5.staticflickr.com-20876-1543621428.1.jpg) #15 in the illustration PN 914 512 319 10 Mine is the original with the metal channel. Seems like it should just gently pry off, but it doesn't. Thanks |
DickSteinkamp |
Nov 30 2018, 06:05 PM
Remove the engine lid first?
mgphoto |
Nov 30 2018, 06:46 PM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
DickSteinkamp |
Nov 30 2018, 07:21 PM
I can see installing without removing the engine lid, but I can't see a way to get vice grips on the metal part of the old seal without removing the lid.
Tricks? |
914Sixer |
Dec 1 2018, 11:46 AM
914 Guru Group: Members Posts: 8,885 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Try starting it with a putty knife or screwdriver. Watch for flying pieces when you get started pulling with pliers.
Dec 1 2018, 12:11 PM
I would definitely remove the engine lid!
Lo-Fi Version | Time is now: 19th May 2024 - 06:47 PM |
