2.0l engine with 1.8 heads - what FI set up to use? |
Tdskip |
Dec 3 2018, 07:39 AM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Counter to popular belief I do not stay up late inventing hairbrained questions for you all, although that is tempting sometime given the wealth of knowledge here. As of around 10:30 AM today this will be a real life scenario.
Let’s imagine I have a 2.0l case running 1.8 heads with a single Weber that runs but I want to convert back to FI. Let’s further image that I have both a 1.8 FI set up and a 2.0 FI set up sitting in the shelf. Which FI set up would I be best advised to use on this engine, and for bonus points and adding to the community knowledge here, why? BTW - planning on doing a tech day on this with/for the SoCal mafia once I get a plan together. Given what seems to be a trend back to FI (or at least renewed interest) I think it could be a useful tech day for the community. Thanks! |
TheCabinetmaker |
Dec 3 2018, 08:13 AM
I drive my car everyday Group: Members Posts: 8,300 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
2.0 intake tubes and throttle body will not fit in 1.8 heads without modification. I would get 2.0 heads and 96mm pistons and build a true 2056. Why fart around cobbling crap together when the proper parts are readily available?
Tdskip |
Dec 3 2018, 08:26 AM
2.0 intake tubes and throttle body will not fit in 1.8 heads without modification. I would get 2.0 heads and 96mm pistons and build a true 2056. Why fart around cobbling crap together when the proper parts are readily available? Good morning, hope you had a good weekend. To answer your question-because I have other projects and wanted to see if there was a "easy "way to simply swap out the car for FI based on what I had access to on the shelf. Building/refreshing an engine is on my to do list of skills to acquire, but that seems a lot more involved then swapping out an FI system. So run the 1.8 L set up since it'll work with the heads? Would that result in less fuel flow them with the 2 L engine wants or is the system capable of keeping up for street use? |
Lo-Fi Version | Time is now: 17th May 2024 - 05:36 AM |
