2.0l engine with 1.8 heads - what FI set up to use? |
Tdskip |
Dec 3 2018, 07:39 AM
Counter to popular belief I do not stay up late inventing hairbrained questions for you all, although that is tempting sometime given the wealth of knowledge here. As of around 10:30 AM today this will be a real life scenario.
Let’s imagine I have a 2.0l case running 1.8 heads with a single Weber that runs but I want to convert back to FI. Let’s further image that I have both a 1.8 FI set up and a 2.0 FI set up sitting in the shelf. Which FI set up would I be best advised to use on this engine, and for bonus points and adding to the community knowledge here, why? BTW - planning on doing a tech day on this with/for the SoCal mafia once I get a plan together. Given what seems to be a trend back to FI (or at least renewed interest) I think it could be a useful tech day for the community. Thanks! |
Mark Henry |
Dec 3 2018, 08:57 AM
Only power loss will be because of the 1.8 vs 2.0 heads.
Tdskip |
Dec 3 2018, 09:06 AM
Only power loss will be because of the 1.8 vs 2.0 heads. Mark! Thanks for both responses. Can we drill into some of the details here, both for my benefit but also to add to the knowledge base if people search on this topic again? It looks like the 1.8 L in the 2.0 L fuel injectors or a different part number, are they actually interchangeable or do they have different flow rates etc? It would seem, yes I've actually been doing some research, that you can't enter interchange the 1.8 L in the 2.0 L components, so sticking with a complete 1.8 or 2.0 L is the way to go, correct? Will the 2.0 L system bolt on to an engine with 1.8 L heads? It seems like there is some debate whether that will work or not? Thanks! |
Lo-Fi Version | Time is now: 2nd May 2024 - 07:15 AM |
