2.0l engine with 1.8 heads - what FI set up to use? |
Tdskip |
Dec 3 2018, 07:39 AM
Counter to popular belief I do not stay up late inventing hairbrained questions for you all, although that is tempting sometime given the wealth of knowledge here. As of around 10:30 AM today this will be a real life scenario.
Let’s imagine I have a 2.0l case running 1.8 heads with a single Weber that runs but I want to convert back to FI. Let’s further image that I have both a 1.8 FI set up and a 2.0 FI set up sitting in the shelf. Which FI set up would I be best advised to use on this engine, and for bonus points and adding to the community knowledge here, why? BTW - planning on doing a tech day on this with/for the SoCal mafia once I get a plan together. Given what seems to be a trend back to FI (or at least renewed interest) I think it could be a useful tech day for the community. Thanks! |
TheCabinetmaker |
Dec 3 2018, 10:53 AM
I drive my car everyday Group: Members Posts: 8,300 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
The 1.7\1.8 runners are longer and don't line up with the 2.0 plenum. They don't have the same bolt pattern. The throttle body is smaller. You can ask the same question 3 times and word the q different, but it doesn't change the answer.
Mark Henry |
Dec 6 2018, 09:19 AM
The 1.7\1.8 runners are longer and don't line up with the 2.0 plenum. They don't have the same bolt pattern. The throttle body is smaller. You can ask the same question 3 times and word the q different, but it doesn't change the answer. I've done it just about every way with Ljet and aftermarket FI. -1.8 runner to 2.0 plenum you have to cut down the runners and tweek one runner each side with a bit of heat. -2.0 runner to 1.8 plenum the runner comes up a bit short, I use coolant hose, you don't have to tweak the runners. -You can't just redrill 2.0 runners for 1.7/1.8 heads (or vice versa) as the ports won't match up and not enough meat to match port. |
Lo-Fi Version | Time is now: 1st May 2024 - 07:15 PM |
