> 2.0l engine with 1.8 heads - what FI set up to use?
Tdskip
post Dec 3 2018, 07:39 AM
Post #21
Counter to popular belief I do not stay up late inventing hairbrained questions for you all, although that is tempting sometime given the wealth of knowledge here. As of around 10:30 AM today this will be a real life scenario.
Let’s imagine I have a 2.0l case running 1.8 heads with a single Weber that runs but I want to convert back to FI.
Let’s further image that I have both a 1.8 FI set up and a 2.0 FI set up sitting in the shelf.
Which FI set up would I be best advised to use on this engine, and for bonus points and adding to the community knowledge here, why?
BTW - planning on doing a tech day on this with/for the SoCal mafia once I get a plan together. Given what seems to be a trend back to FI (or at least renewed interest) I think it could be a useful tech day for the community.
Thanks!
Tdskip   2.0l engine with 1.8 heads - what FI set up to use?   Dec 3 2018, 07:39 AM
914Sixer   For me, I would go with pieces from a bus engine. ...   Dec 3 2018, 07:49 AM
Tdskip   For me, I would go with pieces from a bus engine....   Dec 3 2018, 08:18 AM
TheCabinetmaker   2.0 intake tubes and throttle body will not fit in...   Dec 3 2018, 08:13 AM
Tdskip   2.0 intake tubes and throttle body will not fit i...   Dec 3 2018, 08:26 AM
TheCabinetmaker   I'll let the ljet experts answer that   Dec 3 2018, 08:31 AM
Tdskip   I'll let the ljet experts answer that Thank...   Dec 3 2018, 08:41 AM
Mark Henry   I've built a 2.0 head 2056 engine with Ljet, I...   Dec 3 2018, 08:55 AM
Mark Henry   Only power loss will be because of the 1.8 vs 2.0 ...   Dec 3 2018, 08:57 AM
Tdskip   Only power loss will be because of the 1.8 vs 2.0...   Dec 3 2018, 09:06 AM
Yasha7fold   Only power loss will be because of the 1.8 vs 2.0...   Dec 7 2018, 08:54 PM
Mark Henry   Only power loss will be because of the 1.8 vs 2....   Dec 7 2018, 10:32 PM
TheCabinetmaker   Like i said before, not without modification.   Dec 3 2018, 09:09 AM
Tdskip   Like i said before, not without modification. ...   Dec 3 2018, 09:21 AM
dr914@autoatlanta.com   If that is all you have, use the 1.8 fuel injectio...   Dec 3 2018, 09:29 AM
914Sixer   Bus intake runners are 4 bolt vs 914 3 bolt, so th...   Dec 3 2018, 09:31 AM
Tdskip   OK - so intake runners are different. Got it. It ...   Dec 3 2018, 09:36 AM
914_teener   For 1.8 heads you will need to have a hole machine...   Dec 3 2018, 10:21 AM
Tdskip   Thanks Rob. So bus runners, or drill the head for...   Dec 3 2018, 10:32 AM
marksteinhilber   OK, so your running a 2.0 L case which tells me yo...   Dec 3 2018, 10:49 AM
TheCabinetmaker   The 1.7\1.8 runners are longer and don't ...   Dec 3 2018, 10:53 AM
Tdskip   The 1.7\1.8 runners are longer and don't...   Dec 3 2018, 10:57 AM
Mark Henry   The 1.7\1.8 runners are longer and don't...   Dec 6 2018, 09:19 AM
TheCabinetmaker   Bus runners are 1.8 runners. Still won't fit 2...   Dec 3 2018, 10:59 AM
Valy   The 2.0 and 1.8 injections are different in all pa...   Dec 3 2018, 10:59 AM
Valy   BTW, I forgot to mention that if you want to use t...   Dec 3 2018, 11:05 AM
Tdskip   Thanks for the discussion and all the super helpfu...   Dec 3 2018, 12:17 PM
saigon71   Thanks for the discussion and all the super helpf...   Dec 3 2018, 02:24 PM
Dave_Darling   I would go with the L-jet setup, for the reasons a...   Dec 3 2018, 07:12 PM
Tdskip   Thanks Dave, and all. Great discussion and very he...   Dec 3 2018, 08:03 PM
cgnj   Didn't this discussion happen within the last ...   Dec 4 2018, 12:36 AM
ClayPerrine   Use the L-system as is will get you a good running...   Dec 4 2018, 06:22 AM
Valy   Use the L-system as is will get you a good runnin...   Dec 4 2018, 02:43 PM
914_teener   Use the L-system as is will get you a good runni...   Dec 4 2018, 04:04 PM
Tdskip   Thanks gentlemen   Dec 4 2018, 07:27 AM
ClayPerrine   I dug out my old paper manuals from the 1980s when...   Dec 5 2018, 07:24 AM
Tdskip   Great info, thanks. EDIT: I took the lead from Cl...   Dec 5 2018, 07:58 AM
ClayPerrine   Great info, thanks. EDIT: I took the lead from C...   Dec 6 2018, 03:21 PM
Tdskip   Thanks Mark (and gentlemen). It will be a couple...   Dec 6 2018, 09:32 AM
Tdskip   Only working off feel right now but this car feels...   Dec 7 2018, 09:03 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 05:38 PM
