Rebuilt motor sounds broke, 1400 miles but sat for 14 months |
rstover |
Dec 3 2018, 05:08 PM
Member Group: Members Posts: 136 Joined: 15-November 11 From: Kerrville, TX Member No.: 13,785 Region Association: Southwest Region |
When I got the the car back from the paint shop I was anxious to get the motor running. I have made several mistakes. First I should have pulled the motor and had car hauled to paint. Second I think I should have pulled the plugs and sprayed some lubricant into cylinders before starting it when it returned. The car was at the paint shop for 14 months.
When tried to start it it was on jack stands and the seats were not in so the clutch was not in, but I am pretty sure that it was in neutral. It is hard to describe the sound, but sorta like only 2 pistons or 3 were working. This is a LE car with number matched engine so when it did not sound right I did not try again. This was like six weeks ago and it has taken about that long to get over being really pissed at myself. At this point I have removed the engine and removed all the tin wiring and ect. I took it to a shop close by and they were going to check compression and see if they could find out anything obvious. The compression on the rear passenger side was only 30% is what they told me. They were going to check valve clearances and retest. I have no experience with the inside of the engine and am not sure of next step or what might have gone wrong. My first thought was maybe I broke a rod upon not preparing it correctly after setting so long. Always thankful for ideas. |
rstover |
Dec 10 2018, 08:13 PM
Thanks for the comments. I really needed to take a breath. I have been to paranoid about the motor matching from the beginning. Originally I had bought a 2056 on the world and put it in the car and was going to just leave the original motor on ice. Three years ago I changed my mind and had the original rebuilt and put it back in the car. Nearly every day I second guess this decision.
Today I stopped by the shop that is close to me, a small 2 man shop, and he showed me the leak down test. Always hear about the leak down, but did not know how it was done. Hook some gauge to air supply, screw other end into spark plug hole then rotate that cylinder to top. Something like that. Anyway, here is what it showed. Back right 15, front right 25, left rear 27, left front 37. Don't think this shows anything major. I hate to admit, but I am beginning to believe that I did not have the car in neutral when I turned the ignition, thus the weird sound. When it didn't sound right in the first second it wasn't getting a second chance. I think I over reacted. When I get some help I will get it back and check valves and proceed. Thanks for comments. |
Lo-Fi Version | Time is now: 28th May 2024 - 09:17 AM |
