MPS for a 1.7, MPS for a 1.7 |
joeswaim |
Dec 4 2018, 07:57 AM
Newbie Group: Members Posts: 5 Joined: 4-December 15 From: Roswell Ga Member No.: 19,433 Region Association: South East States |
I have a MPS that is in good shape. It holds a vacuum and the primary and secondary coils are good. The problem is that its serial number is 0 280 100 027.
It is not a 0 280 100 049 (for a 1.7 Porsche) Will this work for a 1.7 1973 Porsche 914 with a ECU 0 280 000 037, 013, 038? thanks Joe |
JeffBowlsby |
Dec 4 2018, 08:24 AM
914 Wiring Harnesses Group: Members Posts: 8,510 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
The engine may seem to function with it, but it is not the correct MPS for a 1.7L 914. I found one source that indicated it is for a VW 1.7L T4. You would need to check all engine functions with test equipment to determine what is not optimal.
dr914@autoatlanta.com |
Dec 4 2018, 08:59 AM
914 Guru Group: Members Posts: 7,866 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
it will work ok, they are all so close that you will not notice the difference
I have a MPS that is in good shape. It holds a vacuum and the primary and secondary coils are good. The problem is that its serial number is 0 280 100 027. It is not a 0 280 100 049 (for a 1.7 Porsche) Will this work for a 1.7 1973 Porsche 914 with a ECU 0 280 000 037, 013, 038? thanks Joe |
Lo-Fi Version | Time is now: 19th May 2024 - 01:04 PM |
