Replacing trunk hinge, Success, and hinge bolt mod. |
Olympic 914 |
Dec 4 2018, 02:38 PM
Group: Members Posts: 1,668 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Going to have to repair/replace the trunk hinge on the car this winter. It was repaired before.... but it failed in a different spot. I wonder if the trunk lid gasket was too tight and caused this failure?
I am planning on taking the engine out to make it easier to get in there and position it correctly and do a good job welding. How many of you have done this repair leaving the engine in? I am not an experienced welder and trying to weld it while bent over the fender and trying to even get the mig in there seems too hard. I have already had the engine out twice since last Oct. so I am getting quite good at it. |
dr914@autoatlanta.com |
Dec 4 2018, 05:14 PM
914 Guru Group: Members Posts: 7,864 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
engine in easy if you can spot weld, and now with McMark'd trunk hinge tool, can be retensioned easily
Going to have to repair/replace the trunk hinge on the car this winter. It was repaired before.... but it failed in a different spot. I wonder if the trunk lid gasket was too tight and caused this failure? I am planning on taking the engine out to make it easier to get in there and position it correctly and do a good job welding. How many of you have done this repair leaving the engine in? I am not an experienced welder and trying to weld it while bent over the fender and trying to even get the mig in there seems too hard. I have already had the engine out twice since last Oct. so I am getting quite good at it. |
Lo-Fi Version | Time is now: 17th May 2024 - 12:23 PM |
