Replacing trunk hinge, Success, and hinge bolt mod. |
Olympic 914 |
Dec 4 2018, 02:38 PM
Group: Members Posts: 1,662 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Going to have to repair/replace the trunk hinge on the car this winter. It was repaired before.... but it failed in a different spot. I wonder if the trunk lid gasket was too tight and caused this failure?
I am planning on taking the engine out to make it easier to get in there and position it correctly and do a good job welding. How many of you have done this repair leaving the engine in? I am not an experienced welder and trying to weld it while bent over the fender and trying to even get the mig in there seems too hard. I have already had the engine out twice since last Oct. so I am getting quite good at it. |
mepstein |
Dec 4 2018, 02:40 PM
914-6 GT in waiting Group: Members Posts: 19,246 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
If you don’t need it to be original, Jwest makes a bolt in trunk hinge kit.
jcd914 |
Dec 4 2018, 06:10 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
If you don’t need it to be original, Jwest makes a bolt in trunk hinge kit. (IMG:style_emoticons/default/agree.gif) This was the method I chose. They come with backing plates so the sheet metal is clamped and the load spread out over more metal than the welded bracket. I also like that the pivot is adjustable to help fine tune the trunk lid position. Definitely not for the 'originality crowd' but a good functional solution. Jim |
Lo-Fi Version | Time is now: 30th April 2024 - 10:15 AM |
