Replacing trunk hinge, Success, and hinge bolt mod. |
Olympic 914 |
Dec 4 2018, 02:38 PM
Group: Members Posts: 1,662 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Going to have to repair/replace the trunk hinge on the car this winter. It was repaired before.... but it failed in a different spot. I wonder if the trunk lid gasket was too tight and caused this failure?
I am planning on taking the engine out to make it easier to get in there and position it correctly and do a good job welding. How many of you have done this repair leaving the engine in? I am not an experienced welder and trying to weld it while bent over the fender and trying to even get the mig in there seems too hard. I have already had the engine out twice since last Oct. so I am getting quite good at it. |
dr914@autoatlanta.com |
Dec 4 2018, 05:14 PM
914 Guru Group: Members Posts: 7,822 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
engine in easy if you can spot weld, and now with McMark'd trunk hinge tool, can be retensioned easily
Going to have to repair/replace the trunk hinge on the car this winter. It was repaired before.... but it failed in a different spot. I wonder if the trunk lid gasket was too tight and caused this failure? I am planning on taking the engine out to make it easier to get in there and position it correctly and do a good job welding. How many of you have done this repair leaving the engine in? I am not an experienced welder and trying to weld it while bent over the fender and trying to even get the mig in there seems too hard. I have already had the engine out twice since last Oct. so I am getting quite good at it. |
Dec 4 2018, 05:15 PM
by the way in the back of the tech tips 700 is the procedure and placement diagram
engine in easy if you can spot weld, and now with McMark'd trunk hinge tool, can be retensioned easily Going to have to repair/replace the trunk hinge on the car this winter. It was repaired before.... but it failed in a different spot. I wonder if the trunk lid gasket was too tight and caused this failure? I am planning on taking the engine out to make it easier to get in there and position it correctly and do a good job welding. How many of you have done this repair leaving the engine in? I am not an experienced welder and trying to weld it while bent over the fender and trying to even get the mig in there seems too hard. I have already had the engine out twice since last Oct. so I am getting quite good at it. |
Olympic 914 |
Dec 4 2018, 05:59 PM
by the way in the back of the tech tips 700 is the procedure and placement diagram Just checked my copy of the 700 Tech tips and was unable to find the placement diagram..... (IMG:style_emoticons/default/confused24.gif) |
Dec 5 2018, 03:22 PM
the bottom of page 132
Lo-Fi Version | Time is now: 30th April 2024 - 11:50 AM |
