Replacing trunk hinge, Success, and hinge bolt mod. |
Olympic 914 |
Dec 4 2018, 02:38 PM
Group: Members Posts: 1,662 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Going to have to repair/replace the trunk hinge on the car this winter. It was repaired before.... but it failed in a different spot. I wonder if the trunk lid gasket was too tight and caused this failure?
I am planning on taking the engine out to make it easier to get in there and position it correctly and do a good job welding. How many of you have done this repair leaving the engine in? I am not an experienced welder and trying to weld it while bent over the fender and trying to even get the mig in there seems too hard. I have already had the engine out twice since last Oct. so I am getting quite good at it. |
914forme |
Jan 26 2019, 06:12 PM
(IMG:style_emoticons/default/agree.gif) They look great, that trick was published in Pano a long time ago.
One quick question just for curiosity sake. I see you mounted the shoulder bolt in a what I am thinking was a piece of solid round that you threaded for the shoulder bolt to seat in. So not to ruin the the bolt threads by putting them in your chuck. Am I correct? |
Olympic 914 |
Jan 26 2019, 08:45 PM
(IMG:style_emoticons/default/agree.gif) They look great, that trick was published in Pano a long time ago. One quick question just for curiosity sake. I see you mounted the shoulder bolt in a what I am thinking was a piece of solid round that you threaded for the shoulder bolt to seat in. So not to ruin the the bolt threads by putting them in your chuck. Am I correct? Yes, That, and giving me extra space so I didn't have to worry about crashing into the chuck. and I was able to use the same piece to cross drill the bolt with the drill press. |
914forme |
Jan 26 2019, 11:04 PM
(IMG:style_emoticons/default/agree.gif) They look great, that trick was published in Pano a long time ago. One quick question just for curiosity sake. I see you mounted the shoulder bolt in a what I am thinking was a piece of solid round that you threaded for the shoulder bolt to seat in. So not to ruin the the bolt threads by putting them in your chuck. Am I correct? Yes, That, and giving me extra space so I didn't have to worry about crashing into the chuck. and I was able to use the same piece to cross drill the bolt with the drill press. (IMG:style_emoticons/default/agree.gif) I bought my Lathe and Mill used, and the last owner, not only ran into the chuck, but also expanded the 3 jaw to the point it hit the bed, and cross slide. (IMG:style_emoticons/default/WTF.gif) I could never get the chuck to center properly. New 4 Jaw solved the issue. Tonight I was thinking about a new bed, and cross slide. |
Lo-Fi Version | Time is now: 30th April 2024 - 08:09 AM |
