How to Cap the Brakes Lines for Staging, Seems obvious how to, but not to me |
Highland |
Dec 4 2018, 05:05 PM
Senior Member Group: Members Posts: 511 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
So I'm at the stage where I'm going to drop the brakes and suspension to change bearings, bushings, calipers, rotors, pads, shocks, springs, etc. I plan to start with the rear then move to the front.
So the car will probably be off its wheels for some time while I'm trying to figure this all out. I've emptied the brake reservoir with a turkey baster, but of course there's still fluid in the lines. I'm also thinking it would be easier to bleed the lines if there's fluid in them. My question is where is the best place to disconnect the brake lines (before or after the flex) and what's the best way to cap it so I don't end up with brake fluid on my paint? |
mepstein |
Dec 4 2018, 06:16 PM
914-6 GT in waiting Group: Members Posts: 19,142 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Clamp the flex line closed and remove it at the flex/hard line junction. Put the flex line in a bottle, unclamp and let drain. Replace flex line if you can’t remember the last time it was changed. Flex lines fail when they get old.
Lo-Fi Version | Time is now: 28th March 2024 - 09:54 AM |
