Tonight's PSA is brought to you by Ima Dope (gearbox related) |
Tdskip |
Dec 4 2018, 07:23 PM
If you find yourself as I did yesterday with a new to you car that won't shift properly stop what you are doing and make sure there is oil in the gearbox.
I don't think I did any harm in the two around the block gingerly drive I did before it got recalcitrant, but lesson learned. Thanks to Gabe in HB for the dope slap to stop what I was doing and check. |
injunmort |
Dec 5 2018, 10:42 AM
Senior Member Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
before tearing into yours trans. make sure all the shifter bushings are intact and if a side shifter the cone screw is tight. I have never bought a 914 that had good bushings. I always replace them first.
Tdskip |
Dec 5 2018, 10:54 AM
before tearing into yours trans. make sure all the shifter bushings are intact and if a side shifter the cone screw is tight. I have never bought a 914 that had good bushings. I always replace them first. Thanks - still need to add oil and run it before doing anything. I have replacement coupler bits in hand for the exact reason you mention. Thanks! |
Lo-Fi Version | Time is now: 5th May 2024 - 06:11 PM |
