Replacing "Bracket for Hinge Pillar" |
DickSteinkamp |
Dec 5 2018, 06:26 PM
Senior Member Group: Members Posts: 500 Joined: 27-February 17 From: Bellingham, WA Member No.: 20,876 Region Association: None |
I need to replace the right side Bracket for Hinge Pillar (914 501 030 10)
(IMG:http://www.914world.com/bbs2/uploads_offsite/farm5.staticflickr.com-20876-1544055999.1.jpg) It would be much easier if I could remove the right side Lateral Grill (914 504 012 10) (IMG:http://www.914world.com/bbs2/uploads_offsite/farm5.staticflickr.com-20876-1544056000.2.jpg) How is it fastened in? Thanks! |
rgalla9146 |
Dec 5 2018, 08:02 PM
Advanced Member Group: Members Posts: 4,547 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Is your engine in or out ? It is much easier to do both jobs with the engine out. (IMG:style_emoticons/default/sad.gif)
Make sure you get that hinge base positioned accurately. |
Costa05 |
Dec 6 2018, 11:05 AM
Member Group: Members Posts: 320 Joined: 27-October 16 From: Phoenix, Arizona Member No.: 20,535 Region Association: Southwest Region |
Is your engine in or out ? It is much easier to do both jobs with the engine out. (IMG:style_emoticons/default/sad.gif) Make sure you get that hinge base positioned accurately. (IMG:style_emoticons/default/agree.gif) FWIW the way I addressed correct position was to place the trink lid exactly where you want it (observing body line gaps and aligment to rear of car ), attach hinges, shoulder bolt, brackets on engine bay side, then climb inside engine bay and tack weld the two brackets to the body. Remove it all and finish welding in the brackets. Worked pretty well for me. |
bbrock |
Dec 6 2018, 11:22 AM
Is your engine in or out ? It is much easier to do both jobs with the engine out. (IMG:style_emoticons/default/sad.gif) Make sure you get that hinge base positioned accurately. (IMG:style_emoticons/default/agree.gif) FWIW the way I addressed correct position was to place the trink lid exactly where you want it (observing body line gaps and aligment to rear of car ), attach hinges, shoulder bolt, brackets on engine bay side, then climb inside engine bay and tack weld the two brackets to the body. Remove it all and finish welding in the brackets. Worked pretty well for me. (IMG:style_emoticons/default/agree.gif) +1 That's exactly what I did even with the Tech Tips diagram and instructions in hand. BTW, those speed nuts are not a treat to remove. Best way I found was to squeeze them with pliers until they bend which opens the hole around the post so they slide off. Also not a task I'd want to do with the engine in. Good luck! (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 6th May 2024 - 10:08 PM |
