> Replacing "Bracket for Hinge Pillar"
DickSteinkamp
post Dec 5 2018, 06:26 PM
I need to replace the right side Bracket for Hinge Pillar (914 501 030 10)
(IMG:http://www.914world.com/bbs2/uploads_offsite/farm5.staticflickr.com-20876-1544055999.1.jpg)
It would be much easier if I could remove the right side Lateral Grill (914 504 012 10)
(IMG:http://www.914world.com/bbs2/uploads_offsite/farm5.staticflickr.com-20876-1544056000.2.jpg)
How is it fastened in?
Thanks!
IronHillRestorations
post Dec 13 2018, 09:03 AM
I. I. R. C.
FWIW, I usually add welds to the back side on the nut insert. I've gotten a spinner on that before.
Olympic 914
post Dec 13 2018, 10:05 AM
QUOTE(IronHillRestorations @ Dec 13 2018, 10:03 AM) *
The restoration design piece has the nut insert separate and it has to be welded in from the back.
Haven't done that yet, but what are your thoughts of also putting a few welds on the outside of the insert?
BTW that RD piece is made of pretty thin stuff.. IMHO
dr914@autoatlanta.com
post Dec 13 2018, 10:18 AM
the factory originally welded the two together and that is how we make them, no reason to go through a double welding process
QUOTE(Olympic 914 @ Dec 13 2018, 09:05 AM) *
post Dec 13 2018, 12:04 PM
I. I. R. C.
QUOTE(dr914@autoatlanta.com @ Dec 13 2018, 08:18 AM) *
It doesn't take much time or effort to add some welds to the back, versus grinding that bracket off because the spot welds didn't hold. Your car do as you like.
I've even reinforced those with some 16 gauge, as well as doing a grease mod to the shoulder bolt.
DickSteinkamp   Replacing "Bracket for Hinge Pillar"   Dec 5 2018, 06:26 PM
Larmo63   It has little pins, usually speed nuts on them.   Dec 5 2018, 06:28 PM
rgalla9146   Is your engine in or out ? It is much easier to do...   Dec 5 2018, 08:02 PM
TravisNeff   Is your engine in or out ? It is much easier to d...   Dec 6 2018, 08:45 AM
Costa05   Is your engine in or out ? It is much easier to d...   Dec 6 2018, 11:05 AM
bbrock   Is your engine in or out ? It is much easier to ...   Dec 6 2018, 11:22 AM
DickSteinkamp   Thanks! I think I can do it with the engine i...   Dec 6 2018, 09:44 AM
dr914@autoatlanta.com   it is easy if you know how to weld and have mcmark...   Dec 6 2018, 09:51 AM
DickSteinkamp   Thanks, George. I did get the bracket from you. ...   Dec 6 2018, 10:55 AM
DickSteinkamp   Mission accomplished. http://www.914world.com/bbs...   Dec 12 2018, 07:39 PM
dr914@autoatlanta.com   very nice, we have seen, over the years, a lot of ...   Dec 13 2018, 09:07 AM
bbrock   My hat is off to you. Well done. I know I couldn...   Dec 12 2018, 07:46 PM
Olympic 914   My hat is off to you. Well done. I know I could...   Dec 13 2018, 08:58 AM
DickSteinkamp   BTW, Thanks, Brent, for your hint on removing the ...   Dec 12 2018, 07:48 PM
IronHillRestorations   FWIW, I usually add welds to the back side on the ...   Dec 13 2018, 09:03 AM
Olympic 914   FWIW, I usually add welds to the back side on the...   Dec 13 2018, 10:05 AM
dr914@autoatlanta.com   the factory originally welded the two together and...   Dec 13 2018, 10:18 AM
IronHillRestorations   the factory originally welded the two together an...   Dec 13 2018, 12:04 PM
TravisNeff   Definitely weld the nut to the back. That is a gre...   Dec 13 2018, 09:05 AM
dr914@autoatlanta.com   some of the butchery   Dec 13 2018, 09:20 AM
dr914@autoatlanta.com   one more:   Dec 13 2018, 09:27 AM
DickSteinkamp   Yikes! Not pretty pictures. I think mine was...   Dec 13 2018, 10:38 AM
- Lo-Fi Version Time is now: 16th April 2024 - 06:51 AM
