Educate me on grounds, before something bad happens |
ericoneal |
Dec 5 2018, 08:34 PM
Member Group: Members Posts: 320 Joined: 13-August 12 From: Crestwood, KY Member No.: 14,795 Region Association: South East States |
In addition to my ignition trouble in my other thread, my starter stopped working as well. I took it out tonight and noticed that the solenoid was loose AND the rubber boot thing with (formerly?) braided wires that connects from a lead to the starter body was broke. No connection anymore between the solenoid and the starter.
Took it off: I figure this is some sort of ground for the Solenoid? I put the starter motor back on and ran a wire from that lead to the tranmission ground strap, then went to connect the ground wire back on to the battery and it was really sparky. That didnt seem right, so I then went to attach the new wire to the starter body, and KAPOW! (IMG:style_emoticons/default/w00t.gif) So whats the purpose of the rubber braided thing from the solenoid to the starter? Should I make a connection somewhere else? |
cgnj |
Dec 6 2018, 01:31 AM
Senior Member Group: Members Posts: 623 Joined: 6-March 03 From: Medford, NJ Member No.: 403 Region Association: None |
Well, your not inspiring confidence that you located TDC on your other thread. Here's a link 914 Factory Service Manuals Next time you visit HarborFreight use the coupon for the free meter and pick up a continuity tester.
Lo-Fi Version | Time is now: 5th May 2024 - 05:49 PM |
