Shutting off the engine, Engine won't shut off |
erwindv |
Dec 6 2018, 03:48 AM
Newbie Group: Members Posts: 46 Joined: 17-June 16 From: Belgium Member No.: 20,119 Region Association: Europe |
Arriving home with the car, turning the ignition key to shut off the engine but it keeps on running!!
What could be wrong? Some electrical issue with the ignition switch? Meanwhile, before fixing it, what is the safest way to turn it off? Thx |
bretth |
Dec 6 2018, 08:42 AM
Senior Member Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region |
I seem to remember something about using the wrong tail light bulb causing this problem? Unless I am confusing this with another issue, couldn't find any info on a quick search though. Something about using a single filament bulb instead of a double filament keeps the ignition circuit alive when the key is off.
Dave_Darling |
Dec 7 2018, 04:54 PM
914 Idiot Group: Members Posts: 14,981 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
I seem to remember something about using the wrong tail light bulb causing this problem? Unless I am confusing this with another issue, couldn't find any info on a quick search though. Something about using a single filament bulb instead of a double filament keeps the ignition circuit alive when the key is off. That was me. If you have the wrong bulb in one of the taillight sockets, and you leave the turn signal switch up or down (depending on where the wrong bulb is) the power from the "parking light" feature will feed back through the ignition switch to the ignition and fuel injection systems... Mixing up power and ground will make for very very weird symptoms! Has any electrical work been done on the car since the time it wasn't having this problem? If so, that's the first place to look. --DD |
euro911 |
Dec 8 2018, 04:13 AM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,845 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
I seem to remember something about using the wrong tail light bulb causing this problem? Unless I am confusing this with another issue, couldn't find any info on a quick search though. Something about using a single filament bulb instead of a double filament keeps the ignition circuit alive when the key is off. That was me.If you have the wrong bulb in one of the taillight sockets, and you leave the turn signal switch up or down (depending on where the wrong bulb is) the power from the "parking light" feature will feed back through the ignition switch to the ignition and fuel injection systems... Mixing up power and ground will make for very very weird symptoms! Has any electrical work been done on the car since the time it wasn't having this problem? If so, that's the first place to look. --DD |
Lo-Fi Version | Time is now: 28th April 2024 - 11:32 AM |
