spare wheel storage |
JFG |
Dec 6 2018, 07:39 AM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
I tried to sort the spare wheel today but i'm not sure how they fit.
I have original steel wheel with 165/15 tyre however it sits higher than what i assume is the shelf stand. no matter how i position it, it seems wrong for the shelf to fit on top. If i raise the rear end (by the tank wall) it sits higher tjere and the hold down bracket doesn't line up. no accident damage or other repairs done in that area. There was no spare when i bought it so i have no reference. |
JFG |
Dec 6 2018, 10:39 AM
I have the same wheel as in racers link 5.5j iirc. but may be 4.5.
The white thing under the rim is just a protective sheet whilst i was trial fitting the rim. So if i'm reading/looking at this correctly the rim sits level or lower to the ledge at the front which the shelf sits on, then the shelf is supported at the rear by the wheel. The car is locked/bllocked away until tomorrow so i'll revisit it then. |
dr914@autoatlanta.com |
Dec 6 2018, 10:47 AM
914 Guru Group: Members Posts: 7,832 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
tire and wheel are in correctly, maybe the trunk floor is bent up, maybe post a picture of it
I have the same wheel as in racers link 5.5j iirc. but may be 4.5. The white thing under the rim is just a protective sheet whilst i was trial fitting the rim. So if i'm reading/looking at this correctly the rim sits level or lower to the ledge at the front which the shelf sits on, then the shelf is supported at the rear by the wheel. The car is locked/bllocked away until tomorrow so i'll revisit it then. |
Lo-Fi Version | Time is now: 3rd May 2024 - 03:56 AM |
