Seam welding chassis, Video on how effective it is |
TravisNeff |
Dec 8 2018, 04:20 PM
TravisNeff |
Dec 9 2018, 04:44 PM
Most of us here are all DIY and inexpensive things are great projects. With a 914 the rear of the car is the flexy part. We have an advantage of the 2nd firewall in the front to further box things in between the strut towers. When you can see the whole car flex as you have depicted, it changes how you view what stiffness is.
It would be good to see this on a 914, but twisting at the rear through the trailing arm mounts and stabilizing the front. |
tperazzo |
Dec 9 2018, 07:38 PM
Newbie Group: Members Posts: 14 Joined: 28-July 09 From: Huntington Beach Member No.: 10,619 Region Association: None |
Most of us here are all DIY and inexpensive things are great projects. With a 914 the rear of the car is the flexy part. We have an advantage of the 2nd firewall in the front to further box things in between the strut towers. When you can see the whole car flex as you have depicted, it changes how you view what stiffness is. It would be good to see this on a 914, but twisting at the rear through the trailing arm mounts and stabilizing the front. Yes, that would be cool. The setup is fairly easy and doesn't take a lot time or tools which is why I did it in the first place. That whole video was shot in a day most of which was welding and waiting for the smoke to clear! Time is the main reason I didn't use cement bags or weights to load the bar, because I didn't have time to go to home depot, ha ha. I guess the responsibility lies with the next person who is strengthening a 914. Step on up, I for one would honored if someone repeated or improved what I did in the video. |
Lo-Fi Version | Time is now: 13th May 2024 - 10:22 PM |
