rear brake caliper disassembly, SUCCESS! |
bbrock |
Dec 9 2018, 09:49 AM
I spent yesterday following @Eric_Shea 's how-to instructions on his website and youtube to disassemble my brake calipers to prepare for sending for plating. My car has one early and one late rear caliper that I don't think has anything to do with my problem but just another of many examples of the mismash of early/late parts on my mid-MY 73.
Three and a half of the calipers came apart without a hitch, which is amazing considering this car spent 30 years outside with brake lines opened up. All pistons came out without an unreasonable fight and no fasteners were seized. The problem is with removing the last (inner) piston on that early rear caliper. Spinning the adjuster doesn't move the piston. It feels like the gear is engaged but turn and turn and nothing happens. Cranking the e-brake lever moves the piston out about 3mm and then it goes back when the lever is released. There is no ratcheting of the piston position. I have NOT split the halves of this caliper yet because it is the only one with Ribe fasteners and I'm waiting for my Ribe bit to arrive in the mail. Since the caliper is still together, I tried popping the piston out with compressed air but that does the same as cranking the lever - piston moves out about 3mm and then goes back. I'm not sure what to try next. The only thing I can think is to go ahead and split the caliper and try gently tapping the piston with a wood drift to try to spin it off the adjuster screw. Anyone have a better suggestion? (IMG:style_emoticons/default/confused24.gif) |
Eric_Shea |
Dec 9 2018, 07:34 PM
Teeth are probably broken in the inner adjuster.
The only way to get that inner piston out now is to reassemble the caliper and clamp the outer piston to prevent it from moving. Then, using water or grease, blow the piston shell off the internal mechanism. Then disassemble the caliper and using a pick to hold and spin the mechanism off the adjuster. Once off you can carefully press it back into the piston shell. Then you’ll need to find an inner adjuster. Seeing as how they’re NLA, this all may be moot. Buy a good core for $40-50 and start over. That said, you may find the inner adjuster is fine and everything was just spinning in the shell. Hope that helps. |
Lo-Fi Version | Time is now: 25th May 2024 - 06:19 PM |
