Superior tranny oil, Slight tranny sound....how to make go away? |
second wind |
Dec 10 2018, 02:54 PM
Senior Member Group: Members Posts: 855 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California |
Hey all....maybe I am just hyper sensitive but I think I am hearing my transmission while I drive.....maybe just a little too much. Could just be normal. Anyone know of a super quieting tranny oil? I think I am using Stalube 85-90 or something like that. Thank you very much.
gg |
porschetub |
Dec 21 2018, 12:01 PM
Advanced Member Group: Members Posts: 4,699 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Sure the good doctor is right as he is referring to the 914 trans which he must know' better than anybody,so whats the secret to Swepco ? which the 911 guys all say improves shifting ,etc in those transmissions,no one seems to mention use in the 914 box that I thought was rather similar in design (IMG:style_emoticons/default/confused24.gif) .
Oil samples can't always be trusted ,last large vessel I ran had a massive gearbox failure due to worn out thrust bearing ,a recent oil sample showed no elevated levels of the bearing material in the oil,end result was a 6 month layup and around 1 million to rebuild it. |
mepstein |
Dec 21 2018, 12:14 PM
914-6 GT in waiting Group: Members Posts: 19,272 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Sure the good doctor is right as he is referring to the 914 trans which he must know' better than anybody,so whats the secret to Swepco ? which the 911 guys all say improves shifting ,etc in those transmissions,no one seems to mention use in the 914 box that I thought was rather similar in design (IMG:style_emoticons/default/confused24.gif) . Oil samples can't always be trusted ,last large vessel I ran had a massive gearbox failure due to worn out thrust bearing ,a recent oil sample showed no elevated levels of the bearing material in the oil,end result was a 6 month layup and around 1 million to rebuild it. Our guys have rebuilt dozens of 915 boxes and only use the GL4 80-90 dino oil. |
Chi-town |
Dec 21 2018, 04:25 PM
Senior Member Group: Members Posts: 850 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California |
Sure the good doctor is right as he is referring to the 914 trans which he must know' better than anybody,so whats the secret to Swepco ? which the 911 guys all say improves shifting ,etc in those transmissions,no one seems to mention use in the 914 box that I thought was rather similar in design (IMG:style_emoticons/default/confused24.gif) . Oil samples can't always be trusted ,last large vessel I ran had a massive gearbox failure due to worn out thrust bearing ,a recent oil sample showed no elevated levels of the bearing material in the oil,end result was a 6 month layup and around 1 million to rebuild it. Our guys have rebuilt dozens of 915 boxes and only use the GL4 80-90 dino oil. Some data is better than no data. If you do an analysis on a regular basis you should have seen something. There is no secret to Swepco, I've run it and it's a good oil just super expensive for anything but race cars. @mepstein have you tried Motul? |
mepstein |
Dec 21 2018, 04:40 PM
Sure the good doctor is right as he is referring to the 914 trans which he must know' better than anybody,so whats the secret to Swepco ? which the 911 guys all say improves shifting ,etc in those transmissions,no one seems to mention use in the 914 box that I thought was rather similar in design (IMG:style_emoticons/default/confused24.gif) . Oil samples can't always be trusted ,last large vessel I ran had a massive gearbox failure due to worn out thrust bearing ,a recent oil sample showed no elevated levels of the bearing material in the oil,end result was a 6 month layup and around 1 million to rebuild it. Our guys have rebuilt dozens of 915 boxes and only use the GL4 80-90 dino oil. Some data is better than no data. If you do an analysis on a regular basis you should have seen something. There is no secret to Swepco, I've run it and it's a good oil just super expensive for anything but race cars. @mepstein have you tried Motul? The customers might but ever trans at the shop gets the regular stuff. I wish I had the chance to watch Russo rebuild the 962 trans. Half the internals were titanium. I was busy with other stuff (IMG:style_emoticons/default/headbang.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 09:29 PM |
