Voltage discrepancy, WTF? |
saigon71 |
Dec 11 2018, 06:17 PM
Senior Member Group: Members Posts: 1,998 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
As long as I can remember, when driving at night in the 914, my center console voltmeter hovers right around 12V when cruising with the lights on. When I hit the brakes, it drops well below 12V...anything else drops it even lower.
I'm running an Optima Red Top near the end of it's service life and want to make sure my charging system is healthy before popping on a new AGM battery. I had been considering switching to LED headlights and brake lights to lower the current draw. I hooked up the VOM at the battery and did a load test with the car running, adding an accessory at a time. With headlights, brake lights and aux fan on the voltmeter in the center console read just over as 10 volts, while the VOM hooked to the battery showed 12.58V. Is this discrepancy normal? |
PanelBilly |
Dec 11 2018, 08:08 PM
914 Guru Group: Members Posts: 5,805 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
I added a new ground wire to mine and that fixed it
Lo-Fi Version | Time is now: 12th May 2024 - 07:15 AM |
