Fire extinguisher recommendations?, Time to replace. |
mountainroads |
Dec 13 2018, 10:08 AM
Member Group: Members Posts: 210 Joined: 19-February 12 From: Seattle Member No.: 14,145 Region Association: Pacific Northwest |
This topic has probably come up before, I honestly tried the search function with several options, but couldn't find anything??
The in-cabin fire extinguisher that came with the car is up for renewal. I'm a cheap bastard at heart, but this doesn't seem like the right time to cheap out and forego a replacement, even if it's for something I hope I'll never have to use. Especially since even the "good" ones I saw were all sub-$100 (?) I like the idea of keeping handy in the cabin instead of one of the trunks. Realize that comes with some space and mounting considerations. FWIW: My existing unit was mounted parallel to the tunnel and ahead of the shifter (no center console box). What does this esteemed knowledge base use and where/how do you mount? Thanks in advance for recommendations. - MR PS: Hope I'm not opening another religious debate, similar to "What's the best engine oil?" (IMG:style_emoticons/default/smile.gif) |
oakdalecurtis |
Dec 13 2018, 12:14 PM
Oakdalecurtis Group: Members Posts: 1,325 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
Here's my fire solution(s). I have a BlazeCut system installed under the lid. I do not use a rain tray since I NEVER drive in the wet. I painted the BlazeCut tube black so that it does not show through the engine cover. You might also notice the engine deck lid steel cable restraint on the left side so that when I pop the lid, the hinges aren't slammed and worked until breakage ensues.
And just in case I have a cabin fire, I have a Kidde extinguisher inside my custom built center console box..... (IMG:style_emoticons/default/piratenanner.gif) |
11tenths |
Dec 13 2018, 03:40 PM
Ve get too soon old, und too late schmart Group: Members Posts: 142 Joined: 11-October 12 From: Islip, Long Island, NY Member No.: 15,026 Region Association: North East States |
Here's my fire solution(s). I have a BlazeCut system installed under the lid. I do not use a rain tray since I NEVER drive in the wet. I painted the BlazeCut tube black so that it does not show through the engine cover. You might also notice the engine deck lid steel cable restraint on the left side so that when I pop the lid, the hinges aren't slammed and worked until breakage ensues. And just in case I have a cabin fire, I have a Kidde extinguisher inside my custom built center console box..... (IMG:style_emoticons/default/piratenanner.gif) Kinda ironic you have a Crane "FireBall" right under your Blaze-Cut. |
oakdalecurtis |
Dec 13 2018, 04:28 PM
Here's my fire solution(s). I have a BlazeCut system installed under the lid. I do not use a rain tray since I NEVER drive in the wet. I painted the BlazeCut tube black so that it does not show through the engine cover. You might also notice the engine deck lid steel cable restraint on the left side so that when I pop the lid, the hinges aren't slammed and worked until breakage ensues. And just in case I have a cabin fire, I have a Kidde extinguisher inside my custom built center console box..... (IMG:style_emoticons/default/piratenanner.gif) Kinda ironic you have a Crane "FireBall" right under your Blaze-Cut. Don’t you believe in ying and yang?? (IMG:style_emoticons/default/grouphug.gif) |
Lo-Fi Version | Time is now: 18th May 2024 - 04:10 PM |
