Cold start troubles, I daily drive mine so I need to get this sorted |
Neil914 |
Dec 14 2018, 12:07 AM
Newbie Group: Members Posts: 26 Joined: 10-September 14 From: Southern CA Member No.: 17,887 Region Association: Rocky Mountains |
So I'll try to cover this neatly. I have a '73 2.0 with fuel injection
My 914 does not start cold with the starter motor. Every morning I roll it backwards out of the driveway backwards and then give it a running push down the gentle slope of my street. It will start cold no problem if you bump start it and get the engine turning over at 1,500 or 2,000 rpm. When I cranked the car over for a while I the engine would get flooded and smell of fuel, and then backfire significantly when bump started. Replacing the head temp sensor has helped that, but did not fix the whole problem. The Auxiliary air valve is dodgy and the car often idles high, but plugged or left open it makes no difference. The car used to start great cold and the problem has actually been gradual. When warm the car starts flawlessly. For the first couple minutes of running when cold the engine can die at idle due to the use of the brakes or headlights, presumably because this drops the voltage. I have tried jumper cables from another car to make sure I have plenty of volts but it still doesn't go. Ideas? Thanks |
JeffBowlsby |
Dec 14 2018, 12:26 AM
914 Wiring Harnesses Group: Members Posts: 8,507 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Transmission ground strap, battery ground and power cable clean?
Ignition timing and valve adjustment? Dirty spark plugs? Cap & rotor? Dirty injectors incl the cold start injector? Trigger points clean and working? Fuel pressure? |
Neil914 |
Jan 5 2019, 08:43 PM
What might the problem with my cap and rotor?
Lo-Fi Version | Time is now: 17th May 2024 - 01:57 AM |
