Inserting Nylon Shifter Bushing, Cannot get it into the Firewall |
ctc911ctc |
Dec 14 2018, 05:00 PM
Senior Member Group: Members Posts: 892 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
Hi,
OK, after 3 hours of trying I gave up for today. '74 2.0, shifter was loose, hitting R on the 1-2 shift. All of the bushings were shot, bought new ones from 914R, they looked super sturdy, very hard Nylon. Started with the one up front, Firewall bushing. Could not get it into the car. Started by heating them in boiling water. Tried pushing them in with: large screw driver Larger Screw Driver Socket (big) Long Pipe the OD being the size of the busing Pipe and a Hammer Pipe and a Bigger Hammer Boiled it each time to hopefully soften it up a bit. Good news is the bushing is still in good shape, man is that things strong. Any hints? Have a call into 914R, trying to get a jump on this with this post so I can drive the car this weekend! Thanks! CTC911CTC |
iankarr |
Dec 15 2018, 11:13 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,473 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
The tangerine racing bushing/setup is another great option. And it doesn’t require removing the front shift rod. You may have to grind down the coupler by a mm or so, but it’s a 3 hole and pop rivet install...
Lo-Fi Version | Time is now: 14th May 2024 - 12:26 AM |
