Fog lights not getting power, What else to check? |
saigon71 |
Dec 15 2018, 01:27 PM
Senior Member Group: Members Posts: 1,997 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
My fog lights don't work on either side. After trying different bulbs, I tested for power with a VOM - no power. Next, I swapped the fog light relay out with several others...still no power.
What are the next logical things to check? Do the fog light switches go bad? Thanks. |
orangecrate |
Dec 15 2018, 01:39 PM
Member Group: Members Posts: 152 Joined: 16-September 13 From: Apache Junction AZ Member No.: 16,394 Region Association: Southwest Region |
Everything goes bad eventually. Did you check your grounds? And the fuse?
saigon71 |
Dec 15 2018, 01:46 PM
orangecrate |
Dec 15 2018, 01:47 PM
Camh Ran Bay 70/71 USN
DickSteinkamp |
Dec 15 2018, 02:32 PM
Senior Member Group: Members Posts: 500 Joined: 27-February 17 From: Bellingham, WA Member No.: 20,876 Region Association: None |
You are probably way ahead of me on this, but just to be sure...
The key has to be on and the headlights have to be on low beam. |
oakdalecurtis |
Dec 15 2018, 03:33 PM
Oakdalecurtis Group: Members Posts: 1,323 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
Bet money that Dick is right, you have the high beams on. If you’re any good at electrical, rewire the fog lights to an independent switch and relay so you can operate them separately from your headlights. I use my foglights that way as daytime running lights. (IMG:style_emoticons/default/beerchug.gif)
porschetub |
Dec 15 2018, 03:35 PM
You are probably way ahead of me on this, but just to be sure... The key has to be on and the headlights have to be on low beam. Good points,you could check for voltage @ your fuseboard ,foglight relay pin #30 to at least isolate that as an issue then you know its further down the line,if that's ok it may be your switch but less likely. Go well (IMG:style_emoticons/default/beerchug.gif) . |
Tbrown4x4 |
Dec 15 2018, 08:36 PM
Senior Member Group: Members Posts: 702 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
You are probably way ahead of me on this, but just to be sure... The key has to be on and the headlights have to be on low beam. Oh man. I have a '73 and the fogs only turn on when my high beams are ON. I always thought that was stupid. Who uses their high beams in the fog? I plan on re-wiring mine to provide voltage to the fog lamp relay so I can use them independantly as well. |
ClayPerrine |
Dec 15 2018, 10:13 PM
Life's been good to me so far..... Group: Admin Posts: 15,410 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
JWest engineering has a kit to convert the fog lights to turn on without the headlamps being on at all.
Highly recommend this. I use the fogs as daytime running lights to help the idiots out there to see me coming. |
76-914 |
Dec 15 2018, 10:40 PM
JWest engineering has a kit to convert the fog lights to turn on without the headlamps being on at all. Highly recommend this. I use the fogs as daytime running lights to help the idiots out there to see me coming. IIRC, someone posted a "work around" using a jumper or switching legs on the headlamp switch so you didn't need the JWest kit. (IMG:style_emoticons/default/confused24.gif) |
DickSteinkamp |
Dec 17 2018, 07:34 PM
Oh man. I have a '73 and the fogs only turn on when my high beams are ON. I always thought that was stupid. Who uses their high beams in the fog? It sounds like they are set up to be used as driving lights...not fog lights. Did any 914s come with optional driving lights? |
JeffBowlsby |
Dec 17 2018, 08:09 PM
914 Wiring Harnesses Group: Members Posts: 8,477 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
The euro market cars were driving lights. USA market cars, fog lights.
porschetub |
Dec 17 2018, 11:50 PM
Bet money that Dick is right, you have the high beams on. If you’re any good at electrical, rewire the fog lights to an independent switch and relay so you can operate them separately from your headlights. I use my foglights that way as daytime running lights. (IMG:style_emoticons/default/beerchug.gif) Done for safety reasons,in my country you can't have it anything different. Would like the daylight setup but not an option for me bugger it. |
RickS |
Dec 17 2018, 11:55 PM
Senior Member Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
Mark Henry |
Dec 18 2018, 07:14 AM
JWest engineering has a kit to convert the fog lights to turn on without the headlamps being on at all. Highly recommend this. I use the fogs as daytime running lights to help the idiots out there to see me coming. IIRC, someone posted a "work around" using a jumper or switching legs on the headlamp switch so you didn't need the JWest kit. (IMG:style_emoticons/default/confused24.gif) How to rewire you driving/fog lights. https://members.rennlist.com/demick/fogrewire.html |
76-914 |
Dec 18 2018, 12:52 PM
JWest engineering has a kit to convert the fog lights to turn on without the headlamps being on at all. Highly recommend this. I use the fogs as daytime running lights to help the idiots out there to see me coming. IIRC, someone posted a "work around" using a jumper or switching legs on the headlamp switch so you didn't need the JWest kit. (IMG:style_emoticons/default/confused24.gif) How to rewire you driving/fog lights. https://members.rennlist.com/demick/fogrewire.html Ta Dah, that's it Mark. I bookmarked it this time. (IMG:style_emoticons/default/beerchug.gif) |
Spoke |
Dec 18 2018, 09:30 PM
Jerry Group: Members Posts: 6,973 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
My fog lights don't work on either side. After trying different bulbs, I tested for power with a VOM - no power. Next, I swapped the fog light relay out with several others...still no power. What are the next logical things to check? Do the fog light switches go bad? Thanks. Do your high beams work? If the one high beam that powers the fog light relay is burned out, the relay will never close and power the fogs. |
underdog |
Dec 19 2018, 10:28 AM
Member Group: Members Posts: 82 Joined: 20-September 11 From: Mountain Home, AR Member No.: 13,579 Region Association: None |
cary |
Dec 19 2018, 10:47 AM
Mark Henry |
JWest engineering has a kit to convert the fog lights to turn on without the headlamps being on at all. Highly recommend this. I use the fogs as daytime running lights to help the idiots out there to see me coming. IIRC, someone posted a "work around" using a jumper or switching legs on the headlamp switch so you didn't need the JWest kit. (IMG:style_emoticons/default/confused24.gif) How to rewire you driving/fog lights. https://members.rennlist.com/demick/fogrewire.html Ta Dah, that's it Mark. I bookmarked it this time. (IMG:style_emoticons/default/beerchug.gif) Also linked to that page is the original Pilot light DIY fog light how to. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 25th April 2024 - 12:57 PM |
