Fog lights not getting power, What else to check? |
saigon71 |
Dec 15 2018, 01:27 PM
Senior Member Group: Members Posts: 1,999 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
My fog lights don't work on either side. After trying different bulbs, I tested for power with a VOM - no power. Next, I swapped the fog light relay out with several others...still no power.
What are the next logical things to check? Do the fog light switches go bad? Thanks. |
Tbrown4x4 |
Dec 15 2018, 08:36 PM
Senior Member Group: Members Posts: 704 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
You are probably way ahead of me on this, but just to be sure... The key has to be on and the headlights have to be on low beam. Oh man. I have a '73 and the fogs only turn on when my high beams are ON. I always thought that was stupid. Who uses their high beams in the fog? I plan on re-wiring mine to provide voltage to the fog lamp relay so I can use them independantly as well. |
Lo-Fi Version | Time is now: 25th May 2024 - 07:27 PM |
