Fog lights not getting power, What else to check? |
saigon71 |
Dec 15 2018, 01:27 PM
Senior Member Group: Members Posts: 1,999 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
My fog lights don't work on either side. After trying different bulbs, I tested for power with a VOM - no power. Next, I swapped the fog light relay out with several others...still no power.
What are the next logical things to check? Do the fog light switches go bad? Thanks. |
ClayPerrine |
Dec 15 2018, 10:13 PM
Life's been good to me so far..... Group: Admin Posts: 15,469 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
JWest engineering has a kit to convert the fog lights to turn on without the headlamps being on at all.
Highly recommend this. I use the fogs as daytime running lights to help the idiots out there to see me coming. |
76-914 |
Dec 15 2018, 10:40 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,502 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
JWest engineering has a kit to convert the fog lights to turn on without the headlamps being on at all. Highly recommend this. I use the fogs as daytime running lights to help the idiots out there to see me coming. IIRC, someone posted a "work around" using a jumper or switching legs on the headlamp switch so you didn't need the JWest kit. (IMG:style_emoticons/default/confused24.gif) |
Mark Henry |
Dec 18 2018, 07:14 AM
JWest engineering has a kit to convert the fog lights to turn on without the headlamps being on at all. Highly recommend this. I use the fogs as daytime running lights to help the idiots out there to see me coming. IIRC, someone posted a "work around" using a jumper or switching legs on the headlamp switch so you didn't need the JWest kit. (IMG:style_emoticons/default/confused24.gif) How to rewire you driving/fog lights. https://members.rennlist.com/demick/fogrewire.html |
Lo-Fi Version | Time is now: 18th May 2024 - 05:08 PM |
