Fog lights not getting power, What else to check? |
saigon71 |
Dec 15 2018, 01:27 PM
Senior Member Group: Members Posts: 1,999 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
My fog lights don't work on either side. After trying different bulbs, I tested for power with a VOM - no power. Next, I swapped the fog light relay out with several others...still no power.
What are the next logical things to check? Do the fog light switches go bad? Thanks. |
DickSteinkamp |
Dec 15 2018, 02:32 PM
Senior Member Group: Members Posts: 500 Joined: 27-February 17 From: Bellingham, WA Member No.: 20,876 Region Association: None |
You are probably way ahead of me on this, but just to be sure...
The key has to be on and the headlights have to be on low beam. |
porschetub |
Dec 15 2018, 03:35 PM
Advanced Member Group: Members Posts: 4,702 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
You are probably way ahead of me on this, but just to be sure... The key has to be on and the headlights have to be on low beam. Good points,you could check for voltage @ your fuseboard ,foglight relay pin #30 to at least isolate that as an issue then you know its further down the line,if that's ok it may be your switch but less likely. Go well (IMG:style_emoticons/default/beerchug.gif) . |
saigon71 |
Dec 22 2018, 04:53 PM
You are probably way ahead of me on this, but just to be sure... The key has to be on and the headlights have to be on low beam. Good points,you could check for voltage @ your fuseboard ,foglight relay pin #30 to at least isolate that as an issue then you know its further down the line,if that's ok it may be your switch but less likely. Go well (IMG:style_emoticons/default/beerchug.gif) . I've got 12V at fuse #10 and foglight relay pin #30. |
Lo-Fi Version | Time is now: 25th May 2024 - 06:00 AM |
