Fog lights not getting power, What else to check? |
saigon71 |
Dec 15 2018, 01:27 PM
Senior Member Group: Members Posts: 1,999 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
My fog lights don't work on either side. After trying different bulbs, I tested for power with a VOM - no power. Next, I swapped the fog light relay out with several others...still no power.
What are the next logical things to check? Do the fog light switches go bad? Thanks. |
76-914 |
Dec 24 2018, 11:16 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,502 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I chased a problem similar to this. The relay and it's rubber socket had passed voltage/continuity tests a few times. When moving the relay harness out of the way ( I was working on another problem at the time and had given up on that circuit) I heard it click and found that circuit now working. When the fuse panel was reconnected it quit working. (IMG:style_emoticons/default/WTF.gif) I found that when that harness was in a "certain position" it did not function. The break was inside the rubber plug and when placed in that certain position it would break the connection. Otherwise it was good. Luck was with me that day. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 18th May 2024 - 01:34 PM |
