Ride height and how much should the suspension bounce |
Tdskip |
Dec 16 2018, 08:17 AM
In the continuing journey to learn about these I took your coaching from an earlier thread on rear suspensions.
1) I measured my ride height from the doughnuts Driver front 5.25 Driver rear 5.60 Passenger front 5.25 Passenger rear 5.60 I quite like how she sits so I’m inclined to call this good but am curious how this compares to yours? 2) I tried the fender bounce test and was surprised by what I found. My front shocks have almost zero movement. There is basically zero movement when I try to bounce the driver side front and only a little on the passenger side front. The driver side feels like a rock. Not sure what normal should feel like here... 3) The rear shocks move as I would expect then to, evenly on both sides but look to be the white Monroe (?) ones. 4) the car is a go cart on smooth pavement but is too harsh over bumps and not compliant enough for comfortable road use. 5) is the tie rod angle shown in the picture, basically level, considered correct? Can you guys take me to school on this all please? |
Larmo63 |
Dec 16 2018, 10:49 AM
Advanced Member Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
If the car is worth keeping and developing, I would start with new Bilsteins/Konis. It may depend on your budget too. If you are going to go five lug, on the front find later 911 3 1/2" Bilstein struts and be done with it.
If you are staying four lug, the same holds true. New shocks. You are most likely going to want to rebuild with: new A arm bushings - I'd go with Elephant Rubber or 914 Rubber Turbo tie rods Lemfoerder ball joints Bilstein HD or Koni shocks all around new swing arm bushings Clean, Powdercoat and plate before assembly While you are in there; brakes, bearings, etc. It really depends on your budget and how far you want to take this car. Slippery slope. |
Lo-Fi Version | Time is now: 15th May 2024 - 05:38 AM |
