Yet Another Horn Gremlin!, Horns not working - group wisdom? |
StarBear |
Dec 17 2018, 10:42 AM
Senior Member Group: Members Posts: 1,886 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
Despite all the postings about horn problems, I have a new one for group wisdom:
1.1974 1.8L; dual horns 335HZ and 400HZ. 2.Original owner (no PO issues!); No long-term storage decay issues – has been is semi-regular use. 3.Horns worked, worked intermittently, then stopped working all together. 4.Horns are OK (tested on direct clip to battery); all other electricals OK; trans ground strap looks OK but haven’t yet cleaned. Cleaned 2 headlight and fuse box grounds. 5.When horn wire touches column ring, the relay clicks (swapped out other known working relays just in case), so connection from horn wire to relay confirmed (so didn’t open steering column to clean inner contacts). 6.Cleaned fuses, fuse contacts and backside fuse connectors. 7.Get only 0.15V across horn hot/ground wires; also across horn hot and ground by headlight. 8.Horn works with hot lead from relay socket 87 (with relay in and ignition on) to horn. Shunt across 30 and 87 gets horn blast, even w/o horn wire touching or ignition on (a clue?). 9.At one time during all the effort, briefly got 12V across the horn wires, but horn didn’t sound (momentary 12V, but insufficient current?). So… seems like the black/yellow power out wire from relay to horn is the issue. Maybe a loose connection in the relay socket (difficult/expensive to change out, but doable)? or bad black/yellow wire to horn has break (how would one ever rewire that, and how to explain intermittent working)? Anything else possible? I’m open to group wisdom on this one… (IMG:style_emoticons/default/wacko.gif) (IMG:style_emoticons/default/headbang.gif) |
Tbrown4x4 |
Jan 9 2019, 09:21 PM
Senior Member Group: Members Posts: 704 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
Relay clicking only means the coil side had power and ground. The contacts can burn and not work properly.
Glad you solved it. I had to rebuild both horns and the low tone still isn't right. |
StarBear |
Jan 10 2019, 07:10 AM
Relay clicking only means the coil side had power and ground. The contacts can burn and not work properly. Glad you solved it. I had to rebuild both horns and the low tone still isn't right. I've read (but not done) that the horns can be tuned through the little black panel on the back. During my adventure I found the little white grommets inside the horn mounting bracket are very important - they isolate the horn from the body. Also cleared/cleaned all the end wires and replaced the terminal clips. Ought to be good for another 45 years... |
Lo-Fi Version | Time is now: 19th May 2024 - 01:00 AM |
