Steering Rack, Preventative Maintenance? |
bbrock |
Dec 18 2018, 11:55 AM
My steering rack is out (along with all the other parts of the car) and I'm getting ready to spruce it up and install turbo tie rod ends. Is it worth tearing it apart for a thorough cleaning, inspection, and refurbishing while I'm at it? My initial inspection shows it turns freely and smoothly through the whole range by hand. The housing cover looks like it was leaking grease so at a minimum, that needs replaced. The rack has about 100K miles of actual use and 35 years of just sitting. I'm not opposed to opening cans of worms but I have an abundance of cans and want to just open the ones worth opening.
And before somebody says it, I know that 914rubber offers a reasonably priced rebuild service for these, but this it a big, complete resto project on a budget. It only works if I supply all the labor I can. I've read through all the threads I could find on the subject and it doesn't look any harder than other stuff I've tackled. Opinions? |
Rob-O |
Dec 18 2018, 10:11 PM
Senior Member Group: Members Posts: 1,252 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
Word of advice, keep track of the shims. They’re under the small cover in the middle of the rack, bottom. They’re job is to apply a set pressure to the rack gear.
Lo-Fi Version | Time is now: 25th May 2024 - 01:23 PM |
