1973 2.0L Rustoration, Restoration turned OT garage build |
Superhawk996 |
Dec 21 2018, 04:10 PM
914 Guru Group: Members Posts: 5,833 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
I purchased my first 914 back in 1987 (1973 1.7L) and had that car for nearly a decade and I personally put over 100,000 miles on it before it ultimately fell victim to a negligent driver that drove into the back end of it at about 40 mph while the vehicle was stopped at a red light. That rear end crash totaled the vehicle but what is amazing is how well it crumpled (early crush zones!) due to the kink in the frame where the halfshafts are. Everyone walked away unharmed.
I replaced it with a 1991 Miata. Great car in its own right but I've always missed my 914. Purchased this "replacement" in May 2018 as a known poster child for a complete right side longitudinal rustoration. This vehicle had been put into storage inside a pole barn around 2004 as far as I can tell. Vehicle initially purchased in non-running condition: Engine couldn't be started. Transmission shift linkage was disconnected Half shafts and CV's were in pieces, and the wheel stubs were not installed therefore the vehicle couldn't even be rolled without risking having the rear wheel separate from within the bearing. Fiberglass laid into the floorpan . . . that can't be a good sign. Vehicle looks great . . . until I got under it. I spent the better part of the summer putting the items above back together and trying to confirm that it would: 1) Run under its own power 2) Drive though the neighborhood and shift though all gears. Looks pretty nice eh? Here is what is lurking underneath once the rockers came off. and when I started cutting back the rust. Oh my . . . . |
Superhawk996 |
Dec 21 2018, 08:25 PM
So what are the skeletons on this car that I've found so far (other than rust!)?
3 coats of paint. Original is Alaska Blue Metallic. Two repaints in red. Currently done in BMW #138 Cinnabar Car was the victim of an A/C install (DPD parts). I'm very torn on this. My original car didn't have A/C. I had many sweaty summer drives on hot black vinyl seats! Now that I'm older and have enjoyed the A/C on the Miata I think it might be nice. On the other hand, the install is pure butchery! I'm trying to figure out a better way to do this. Maybe route the A/C lines though the tunnel when I have the floor pan off? Maybe do clean bulkhead pass-thru's into the cabin instead of just cutting holes with a hole saw? Same for the York compressor and need to cut the right side engine shelf! No way. There must be a slick way to mount a smaller Sanden compressor and/or do a top side center mount such that the butchery can be avoided. There must be a better way. I've been poking around for ideas but haven'f found the right solution yet. |
Lo-Fi Version | Time is now: 19th May 2024 - 02:44 PM |
