1973 2.0L Rustoration, Restoration turned OT garage build |
Superhawk996 |
Dec 21 2018, 04:10 PM
914 Guru Group: Members Posts: 5,834 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
I purchased my first 914 back in 1987 (1973 1.7L) and had that car for nearly a decade and I personally put over 100,000 miles on it before it ultimately fell victim to a negligent driver that drove into the back end of it at about 40 mph while the vehicle was stopped at a red light. That rear end crash totaled the vehicle but what is amazing is how well it crumpled (early crush zones!) due to the kink in the frame where the halfshafts are. Everyone walked away unharmed.
I replaced it with a 1991 Miata. Great car in its own right but I've always missed my 914. Purchased this "replacement" in May 2018 as a known poster child for a complete right side longitudinal rustoration. This vehicle had been put into storage inside a pole barn around 2004 as far as I can tell. Vehicle initially purchased in non-running condition: Engine couldn't be started. Transmission shift linkage was disconnected Half shafts and CV's were in pieces, and the wheel stubs were not installed therefore the vehicle couldn't even be rolled without risking having the rear wheel separate from within the bearing. Fiberglass laid into the floorpan . . . that can't be a good sign. Vehicle looks great . . . until I got under it. I spent the better part of the summer putting the items above back together and trying to confirm that it would: 1) Run under its own power 2) Drive though the neighborhood and shift though all gears. Looks pretty nice eh? Here is what is lurking underneath once the rockers came off. and when I started cutting back the rust. Oh my . . . . |
Superhawk996 |
Apr 23 2019, 09:27 AM
Here is a bit of previous work. I removed the tunnel to better access the cowl for repair and because it was completely shot.
I figured it would be easier and a better repair to replace it completely rather than patch up what I had. Here is the dissection to show it's internal condition. For any of you having problems removing and/or installing new throttle and/or clutch cables, don't rule out this possibility. When I 1st was getting this car running, the throttle cable was stuck. When I pulled out the old cable, it hung up about half way out. I had to break it to get it out! In order to get the car running, I cut a hole in the tunnel, and cut out a section of the tube and just fished the cable up to the pedal sled. It was a quick fix but wouldn't have been a good long term solution. The photo above shows why! |
Lo-Fi Version | Time is now: 19th May 2024 - 07:41 PM |
