1973 2.0L Rustoration, Restoration turned OT garage build |
Superhawk996 |
Dec 21 2018, 04:10 PM
914 Guru Group: Members Posts: 5,834 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
I purchased my first 914 back in 1987 (1973 1.7L) and had that car for nearly a decade and I personally put over 100,000 miles on it before it ultimately fell victim to a negligent driver that drove into the back end of it at about 40 mph while the vehicle was stopped at a red light. That rear end crash totaled the vehicle but what is amazing is how well it crumpled (early crush zones!) due to the kink in the frame where the halfshafts are. Everyone walked away unharmed.
I replaced it with a 1991 Miata. Great car in its own right but I've always missed my 914. Purchased this "replacement" in May 2018 as a known poster child for a complete right side longitudinal rustoration. This vehicle had been put into storage inside a pole barn around 2004 as far as I can tell. Vehicle initially purchased in non-running condition: Engine couldn't be started. Transmission shift linkage was disconnected Half shafts and CV's were in pieces, and the wheel stubs were not installed therefore the vehicle couldn't even be rolled without risking having the rear wheel separate from within the bearing. Fiberglass laid into the floorpan . . . that can't be a good sign. Vehicle looks great . . . until I got under it. I spent the better part of the summer putting the items above back together and trying to confirm that it would: 1) Run under its own power 2) Drive though the neighborhood and shift though all gears. Looks pretty nice eh? Here is what is lurking underneath once the rockers came off. and when I started cutting back the rust. Oh my . . . . |
Superhawk996 |
Apr 28 2019, 04:49 PM
Well since I'm not supposed to be doing any heavy lifting per doctors orders, I decided to teardown my engine instead of doing bodywork with all the welding and grinding dust to get in the stitches in on my face.
Doc said not to lift more than 5 lbs. I didn't - the hand winch did. (IMG:style_emoticons/default/biggrin.gif) Pretty uneventful weekend but I'm still sticking with the I hate previous owners rant. (IMG:style_emoticons/default/ar15.gif) When I pulled the oil breather off the top of the case I was horrified. Here's what I saw. Worse than the rust debris / garbage there is some sort of round metal object in here. Luckily it was too big to ever fall into the case. I have no idea what this is or where it came from. Any ideas? Here are two views of it |
Dave_Darling |
Apr 28 2019, 07:02 PM
Worse than the rust debris / garbage there is some sort of round metal object in here. Luckily it was too big to ever fall into the case. Interesting. It looks about the right diameter for the cover over the bottom of the PCV valve, but the cover is much thinner. Perhaps it was a home-made block-off for the PCV system? The cover comes to mind because it always seems to fall off and land right in the spot you show --DD. |
bbrock |
Apr 28 2019, 07:31 PM
Worse than the rust debris / garbage there is some sort of round metal object in here. Luckily it was too big to ever fall into the case. Interesting. It looks about the right diameter for the cover over the bottom of the PCV valve, but the cover is much thinner. Perhaps it was a home-made block-off for the PCV system? The cover comes to mind because it always seems to fall off and land right in the spot you show --DD. That was my first thought as well but I just took mine apart to clean and repaint a week ago and the cover was plastic. (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 19th May 2024 - 08:50 PM |
