1973 2.0L Rustoration, Restoration turned OT garage build |
Superhawk996 |
Dec 21 2018, 04:10 PM
914 Guru Group: Members Posts: 5,834 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
I purchased my first 914 back in 1987 (1973 1.7L) and had that car for nearly a decade and I personally put over 100,000 miles on it before it ultimately fell victim to a negligent driver that drove into the back end of it at about 40 mph while the vehicle was stopped at a red light. That rear end crash totaled the vehicle but what is amazing is how well it crumpled (early crush zones!) due to the kink in the frame where the halfshafts are. Everyone walked away unharmed.
I replaced it with a 1991 Miata. Great car in its own right but I've always missed my 914. Purchased this "replacement" in May 2018 as a known poster child for a complete right side longitudinal rustoration. This vehicle had been put into storage inside a pole barn around 2004 as far as I can tell. Vehicle initially purchased in non-running condition: Engine couldn't be started. Transmission shift linkage was disconnected Half shafts and CV's were in pieces, and the wheel stubs were not installed therefore the vehicle couldn't even be rolled without risking having the rear wheel separate from within the bearing. Fiberglass laid into the floorpan . . . that can't be a good sign. Vehicle looks great . . . until I got under it. I spent the better part of the summer putting the items above back together and trying to confirm that it would: 1) Run under its own power 2) Drive though the neighborhood and shift though all gears. Looks pretty nice eh? Here is what is lurking underneath once the rockers came off. and when I started cutting back the rust. Oh my . . . . |
Tenner |
Apr 29 2019, 02:55 AM
Newbie Group: Members Posts: 20 Joined: 22-June 10 From: Germany Member No.: 11,863 Region Association: Germany |
A few posts earlier, you've been talked about the repairpanel of the inner frame section and it bothers you that it's not made like the original which is two layers of steel ...
This bothered me too and I decided to build my own repaipanel. The Panel will be a combination off an own build outer layer and the Restorationdesign repiarpanel as the inner reinforcement layer. This is what I've built so far. The panel is made from one piece of 1.2mm sheetmetal and fits nearly perfect to the inner wheelhouse repiarpanel. It took me about half a year and 4 tries to make it right. I ended up making my own tools to get the edges properly bended. Next step is trim the overlap, fill the gaps, fit the inner layer and finaly fit it to the car before welding it in. If anyone is interested in the building process, I will open a new thread to discribe the process |
Lo-Fi Version | Time is now: 19th May 2024 - 06:13 PM |
