1973 2.0L Rustoration, Restoration turned OT garage build |
Superhawk996 |
Dec 21 2018, 04:10 PM
914 Guru Group: Members Posts: 5,780 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
I purchased my first 914 back in 1987 (1973 1.7L) and had that car for nearly a decade and I personally put over 100,000 miles on it before it ultimately fell victim to a negligent driver that drove into the back end of it at about 40 mph while the vehicle was stopped at a red light. That rear end crash totaled the vehicle but what is amazing is how well it crumpled (early crush zones!) due to the kink in the frame where the halfshafts are. Everyone walked away unharmed.
I replaced it with a 1991 Miata. Great car in its own right but I've always missed my 914. Purchased this "replacement" in May 2018 as a known poster child for a complete right side longitudinal rustoration. This vehicle had been put into storage inside a pole barn around 2004 as far as I can tell. Vehicle initially purchased in non-running condition: Engine couldn't be started. Transmission shift linkage was disconnected Half shafts and CV's were in pieces, and the wheel stubs were not installed therefore the vehicle couldn't even be rolled without risking having the rear wheel separate from within the bearing. Fiberglass laid into the floorpan . . . that can't be a good sign. Vehicle looks great . . . until I got under it. I spent the better part of the summer putting the items above back together and trying to confirm that it would: 1) Run under its own power 2) Drive though the neighborhood and shift though all gears. Looks pretty nice eh? Here is what is lurking underneath once the rockers came off. and when I started cutting back the rust. Oh my . . . . |
Superhawk996 |
Dec 21 2018, 09:08 PM
Also found the driver side suspension console to have some stress cracking that lead to the start of rust. Not entirely surprising now that I suspect the chassis has about 160K miles.
Unfortunately, there is no aftermarket sheet metal to replace the left side. I had a nice e-mail exchange with Restoration Design. It sounds like they are considering tooling up the left side suspension console but that it will take some serious time. I've got to believe that at this point in time, many other "rust free" high mileage 914's are beginning to show their age and have similar stress cracking on the left side. I'm hoping Restoration Design will eventually produce this part. Until then, I'll repair and reinforce it. If you're in need of a left side console, I'd recommend that you reach out to Restoration Design to reinforce the market need for left side suspension console parts!. |
Lo-Fi Version | Time is now: 7th May 2024 - 10:47 PM |
