1973 2.0L Rustoration, Restoration turned OT garage build |
Superhawk996 |
Dec 21 2018, 04:10 PM
914 Guru Group: Members Posts: 5,780 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
I purchased my first 914 back in 1987 (1973 1.7L) and had that car for nearly a decade and I personally put over 100,000 miles on it before it ultimately fell victim to a negligent driver that drove into the back end of it at about 40 mph while the vehicle was stopped at a red light. That rear end crash totaled the vehicle but what is amazing is how well it crumpled (early crush zones!) due to the kink in the frame where the halfshafts are. Everyone walked away unharmed.
I replaced it with a 1991 Miata. Great car in its own right but I've always missed my 914. Purchased this "replacement" in May 2018 as a known poster child for a complete right side longitudinal rustoration. This vehicle had been put into storage inside a pole barn around 2004 as far as I can tell. Vehicle initially purchased in non-running condition: Engine couldn't be started. Transmission shift linkage was disconnected Half shafts and CV's were in pieces, and the wheel stubs were not installed therefore the vehicle couldn't even be rolled without risking having the rear wheel separate from within the bearing. Fiberglass laid into the floorpan . . . that can't be a good sign. Vehicle looks great . . . until I got under it. I spent the better part of the summer putting the items above back together and trying to confirm that it would: 1) Run under its own power 2) Drive though the neighborhood and shift though all gears. Looks pretty nice eh? Here is what is lurking underneath once the rockers came off. and when I started cutting back the rust. Oh my . . . . |
bbrock |
Jan 1 2019, 01:41 PM
Happy New Year! Thanks for posting your clock repair experience. My clock hasn't been plugged in for 35 years and I can't remember if it was even working back then, so I may have to reference this soon.
FYI, I had my local glass shop cut new glass lenses for my tach which had a plastic lens and it was a reasonable price. Lenses on my console gauges look good but I may eventually do the same for them. SEM Trim Black is a dead nuts match for the satin black used on the bezels. I resprayed both inner and outer bezels on my main instrument panel gauges and they look like new. Much cheaper than a full professional restoration at least. I'm curious about the thermal fuse. Is there no way to replace with one with long leads attached so it could be soldered in with normal solder without melting the fuse? Having never seen inside one of these clocks, just wondering (IMG:style_emoticons/default/idea.gif) |
Superhawk996 |
Jan 1 2019, 02:42 PM
I'm curious about the thermal fuse. Is there no way to replace with one with long leads attached so it could be soldered in with normal solder without melting the fuse? Having never seen inside one of these clocks, just wondering (IMG:style_emoticons/default/idea.gif) Pelican forum has a picture that is not very clear - I'll try to post something a bit clearer in a day. The bottom line is that the answer to the question is No. if the internal fuse is melted it needs to be re-soldered. I've read of others just using normal solder and then putting the fuse external to the clock. Per my post, 1/2A fast blow would do the trick. However if the internal fuse melted (as mine was) it would need to be resoldered to get power to the solenoid. If you get closer to doing this, I'd be happy to walk you though it with better pictures or video. https://cdn9.pelicanparts.com/techarticles/...repair/fig3.jpg |
Lo-Fi Version | Time is now: 8th May 2024 - 01:16 PM |
