915 Trans use and Stated Modification question, Has anyone done this modification? |
pdlightning |
Dec 21 2018, 11:47 PM
Member Group: Members Posts: 207 Joined: 4-February 11 From: Santa Clarita Member No.: 12,660 Region Association: Southern California |
I have read when modifying a 915 trans to be installed in the V8 914 that to be sure to shift the transaxle into all the gears after the ring gear is flipped - you will notice that one of the internal shifter rails will need to be shortened - just enough to clear the ring gear.
Ring and pinion sets (4.43, 4.38, 3.88 and 3.10 ratios). As I remember, I got the 3.10 ratio as instructed. Any 914-8 or 914-6 mod people that can comment on this? If this is true, I have to remove and modify my trans again before attempting to drive the car. Also, if it makes a difference, the ring and pinion that is installed is a higher geared for better RPM drivability at top speed with the LS mod. Thanks (IMG:style_emoticons/default/headbang.gif) |
mepstein |
Dec 22 2018, 08:52 AM
914-6 GT in waiting Group: Members Posts: 19,255 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Some clear without any mods, some need some work so nothing rubs. You definitely want to check before you put power to the trans.
pdlightning |
Dec 22 2018, 11:19 PM
Some clear without any mods, some need some work so nothing rubs. You definitely want to check before you put power to the trans. Thanks! (IMG:style_emoticons/default/headbang.gif) |
rgalla9146 |
Dec 23 2018, 09:33 AM
Advanced Member Group: Members Posts: 4,545 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Some clear without any mods, some need some work so nothing rubs. You definitely want to check before you put power to the trans. Hmmmm.....guess I'll be checking the same thing. thanks to both of you for the heads up. I have to go back in anyway.... better now than later. |
GeorgeRud |
Dec 23 2018, 12:44 PM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
Did you use the Wevo, Vellios, or other kit for the conversion?
rgalla9146 |
Dec 23 2018, 12:57 PM
mepstein |
Dec 23 2018, 01:23 PM
Did you use the Wevo, Vellios, or other kit for the conversion? I used a cable shifter for the 915 and the now, nla trans hanger from PMS. Only issue I have is I will need a custom set of mufflers from Ben since the cableshifter sticks too far out the back of the trans to run a normal exhaust. |
pdlightning |
Dec 23 2018, 10:26 PM
Did you use the Wevo, Vellios, or other kit for the conversion? I used a cable shifter for the 915 and the now, nla trans hanger from PMS. Only issue I have is I will need a custom set of mufflers from Ben since the cableshifter sticks too far out the back of the trans to run a normal exhaust. Mine too is a special cable shifter with a MR 2 shifter box. Will be doing an engine/trans cradle to support the LS/915 combo. Also an electric water pump from Maziere. Just don’t know which model yet, maybe a 316. |
914dave |
Dec 24 2018, 05:46 AM
914 Addict Group: Members Posts: 700 Joined: 19-October 03 From: Willow Grove Pa. Member No.: 1,262 Region Association: North East States |
I used the early Vellios kit. None of the shift rods interfered with the ring gear in my case.
GeorgeRud |
Dec 24 2018, 02:03 PM
Mine was also the Vellios kit and had no interference issues.
Larry.Hubby |
Dec 24 2018, 07:07 PM
Member who doesn't post much, but has a long time in 914s Group: Members Posts: 186 Joined: 24-November 04 From: Palo Alto, CA Member No.: 3,172 Region Association: Northern California |
I used a copy of the factory kit made by Vellios (like the Martin Bott kit, not like his later kit that he sold under his own name) for an outfit named Jade Car, and my trans did need the shift rods shortened. The trans I started with was a '78 911SC box.
pdlightning |
Jan 12 2019, 06:56 PM
pdlightning |
Apr 16 2019, 05:55 PM
I have read when modifying a 915 trans to be installed in the V8 914 that to be sure to shift the transaxle into all the gears after the ring gear is flipped - you will notice that one of the internal shifter rails will need to be shortened - just enough to clear the ring gear. Ring and pinion sets (4.43, 4.38, 3.88 and 3.10 ratios). As I remember, I got the 3.10 ratio as instructed. Any 914-8 or 914-6 mod people that can comment on this? If this is true, I have to remove and modify my trans again before attempting to drive the car. Also, if it makes a difference, the ring and pinion that is installed is a higher geared for better RPM drivability at top speed with the LS mod. Thanks (IMG:style_emoticons/default/headbang.gif) TRANS MOD UPDATE I have disassembled the 915 trans with the flopped ring gear. The shift rods tolerances were to close to the ring gear so we shortened them and clearanced the side of the rods that faces the ring gear. Both now clear and trans assembled. This would have been a major destruction to my trans and expensive new ring gear if not for the expertise that is shared on this forum. I appreciate everyone's input and expertise. Mike (IMG:style_emoticons/default/beerchug.gif) |
Jeff Hail |
Apr 20 2019, 07:41 PM
Senior Member Group: Members Posts: 1,141 Joined: 3-May 07 From: LA/ CA Member No.: 7,712 |
I have read when modifying a 915 trans to be installed in the V8 914 that to be sure to shift the transaxle into all the gears after the ring gear is flipped - you will notice that one of the internal shifter rails will need to be shortened - just enough to clear the ring gear. Ring and pinion sets (4.43, 4.38, 3.88 and 3.10 ratios). As I remember, I got the 3.10 ratio as instructed. Any 914-8 or 914-6 mod people that can comment on this? If this is true, I have to remove and modify my trans again before attempting to drive the car. Also, if it makes a difference, the ring and pinion that is installed is a higher geared for better RPM drivability at top speed with the LS mod. Thanks (IMG:style_emoticons/default/headbang.gif) TRANS MOD UPDATE I have disassembled the 915 trans with the flopped ring gear. The shift rods tolerances were to close to the ring gear so we shortened them and clearanced the side of the rods that faces the ring gear. Both now clear and trans assembled. This would have been a major destruction to my trans and expensive new ring gear if not for the expertise that is shared on this forum. I appreciate everyone's input and expertise. Mike (IMG:style_emoticons/default/beerchug.gif) What are using to drive the speedometer? Hall sensor add? |
pdlightning |
Apr 20 2019, 10:11 PM
I have read when modifying a 915 trans to be installed in the V8 914 that to be sure to shift the transaxle into all the gears after the ring gear is flipped - you will notice that one of the internal shifter rails will need to be shortened - just enough to clear the ring gear. Ring and pinion sets (4.43, 4.38, 3.88 and 3.10 ratios). As I remember, I got the 3.10 ratio as instructed. Any 914-8 or 914-6 mod people that can comment on this? If this is true, I have to remove and modify my trans again before attempting to drive the car. Also, if it makes a difference, the ring and pinion that is installed is a higher geared for better RPM drivability at top speed with the LS mod. Thanks (IMG:style_emoticons/default/headbang.gif) TRANS MOD UPDATE I have disassembled the 915 trans with the flopped ring gear. The shift rods tolerances were to close to the ring gear so we shortened them and clearanced the side of the rods that faces the ring gear. Both now clear and trans assembled. This would have been a major destruction to my trans and expensive new ring gear if not for the expertise that is shared on this forum. I appreciate everyone's input and expertise. Mike (IMG:style_emoticons/default/beerchug.gif) What are using to drive the speedometer? Hall sensor add? Bought GPS speedo from Speedhut! |
Lo-Fi Version | Time is now: 5th May 2024 - 03:43 AM |
