915 Trans use and Stated Modification question, Has anyone done this modification? |
pdlightning |
Dec 21 2018, 11:47 PM
Member Group: Members Posts: 207 Joined: 4-February 11 From: Santa Clarita Member No.: 12,660 Region Association: Southern California |
I have read when modifying a 915 trans to be installed in the V8 914 that to be sure to shift the transaxle into all the gears after the ring gear is flipped - you will notice that one of the internal shifter rails will need to be shortened - just enough to clear the ring gear.
Ring and pinion sets (4.43, 4.38, 3.88 and 3.10 ratios). As I remember, I got the 3.10 ratio as instructed. Any 914-8 or 914-6 mod people that can comment on this? If this is true, I have to remove and modify my trans again before attempting to drive the car. Also, if it makes a difference, the ring and pinion that is installed is a higher geared for better RPM drivability at top speed with the LS mod. Thanks (IMG:style_emoticons/default/headbang.gif) |
GeorgeRud |
Dec 23 2018, 12:44 PM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
Did you use the Wevo, Vellios, or other kit for the conversion?
mepstein |
Dec 23 2018, 01:23 PM
914-6 GT in waiting Group: Members Posts: 19,273 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Did you use the Wevo, Vellios, or other kit for the conversion? I used a cable shifter for the 915 and the now, nla trans hanger from PMS. Only issue I have is I will need a custom set of mufflers from Ben since the cableshifter sticks too far out the back of the trans to run a normal exhaust. |
Lo-Fi Version | Time is now: 18th May 2024 - 05:05 PM |
