915 Trans use and Stated Modification question, Has anyone done this modification? |
pdlightning |
Dec 21 2018, 11:47 PM
Member Group: Members Posts: 207 Joined: 4-February 11 From: Santa Clarita Member No.: 12,660 Region Association: Southern California |
I have read when modifying a 915 trans to be installed in the V8 914 that to be sure to shift the transaxle into all the gears after the ring gear is flipped - you will notice that one of the internal shifter rails will need to be shortened - just enough to clear the ring gear.
Ring and pinion sets (4.43, 4.38, 3.88 and 3.10 ratios). As I remember, I got the 3.10 ratio as instructed. Any 914-8 or 914-6 mod people that can comment on this? If this is true, I have to remove and modify my trans again before attempting to drive the car. Also, if it makes a difference, the ring and pinion that is installed is a higher geared for better RPM drivability at top speed with the LS mod. Thanks (IMG:style_emoticons/default/headbang.gif) |
pdlightning |
Apr 16 2019, 05:55 PM
I have read when modifying a 915 trans to be installed in the V8 914 that to be sure to shift the transaxle into all the gears after the ring gear is flipped - you will notice that one of the internal shifter rails will need to be shortened - just enough to clear the ring gear. Ring and pinion sets (4.43, 4.38, 3.88 and 3.10 ratios). As I remember, I got the 3.10 ratio as instructed. Any 914-8 or 914-6 mod people that can comment on this? If this is true, I have to remove and modify my trans again before attempting to drive the car. Also, if it makes a difference, the ring and pinion that is installed is a higher geared for better RPM drivability at top speed with the LS mod. Thanks (IMG:style_emoticons/default/headbang.gif) TRANS MOD UPDATE I have disassembled the 915 trans with the flopped ring gear. The shift rods tolerances were to close to the ring gear so we shortened them and clearanced the side of the rods that faces the ring gear. Both now clear and trans assembled. This would have been a major destruction to my trans and expensive new ring gear if not for the expertise that is shared on this forum. I appreciate everyone's input and expertise. Mike (IMG:style_emoticons/default/beerchug.gif) |
Jeff Hail |
Apr 20 2019, 07:41 PM
Senior Member Group: Members Posts: 1,141 Joined: 3-May 07 From: LA/ CA Member No.: 7,712 |
I have read when modifying a 915 trans to be installed in the V8 914 that to be sure to shift the transaxle into all the gears after the ring gear is flipped - you will notice that one of the internal shifter rails will need to be shortened - just enough to clear the ring gear. Ring and pinion sets (4.43, 4.38, 3.88 and 3.10 ratios). As I remember, I got the 3.10 ratio as instructed. Any 914-8 or 914-6 mod people that can comment on this? If this is true, I have to remove and modify my trans again before attempting to drive the car. Also, if it makes a difference, the ring and pinion that is installed is a higher geared for better RPM drivability at top speed with the LS mod. Thanks (IMG:style_emoticons/default/headbang.gif) TRANS MOD UPDATE I have disassembled the 915 trans with the flopped ring gear. The shift rods tolerances were to close to the ring gear so we shortened them and clearanced the side of the rods that faces the ring gear. Both now clear and trans assembled. This would have been a major destruction to my trans and expensive new ring gear if not for the expertise that is shared on this forum. I appreciate everyone's input and expertise. Mike (IMG:style_emoticons/default/beerchug.gif) What are using to drive the speedometer? Hall sensor add? |
pdlightning |
Apr 20 2019, 10:11 PM
I have read when modifying a 915 trans to be installed in the V8 914 that to be sure to shift the transaxle into all the gears after the ring gear is flipped - you will notice that one of the internal shifter rails will need to be shortened - just enough to clear the ring gear. Ring and pinion sets (4.43, 4.38, 3.88 and 3.10 ratios). As I remember, I got the 3.10 ratio as instructed. Any 914-8 or 914-6 mod people that can comment on this? If this is true, I have to remove and modify my trans again before attempting to drive the car. Also, if it makes a difference, the ring and pinion that is installed is a higher geared for better RPM drivability at top speed with the LS mod. Thanks (IMG:style_emoticons/default/headbang.gif) TRANS MOD UPDATE I have disassembled the 915 trans with the flopped ring gear. The shift rods tolerances were to close to the ring gear so we shortened them and clearanced the side of the rods that faces the ring gear. Both now clear and trans assembled. This would have been a major destruction to my trans and expensive new ring gear if not for the expertise that is shared on this forum. I appreciate everyone's input and expertise. Mike (IMG:style_emoticons/default/beerchug.gif) What are using to drive the speedometer? Hall sensor add? Bought GPS speedo from Speedhut! |
Lo-Fi Version | Time is now: 25th May 2024 - 01:26 PM |
