Where is the leak?, oil after sitting for weeks/months |
fixer34 |
Dec 25 2018, 07:31 PM
Senior Member Group: Members Posts: 1,085 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest |
This has been happening for a long time, but seems to be getting worse. Factory -6, while it is running and for several days sitting there is no oil leakage (OK, maybe a few drops). Anything longer and I start to get a puddle under the passenger side of the engine to the point that I place a large foil pan under the car if I won't be starting/driving it for a while. After a couple months I might have 4 quarts of oil in the pan. I know it is from the dry sump backflowing into the engine, but I can't tell where it is leaking. It is missing the heat exchanger because I don't get the burnt oil smell when starting the car.
Thoughts on where might it be leaking and can it be fixed without pulling the engine? I was thinking about one/both of the oil return tubes, but figured they would leak while it was running. |
euro911 |
Dec 25 2018, 08:32 PM
Rear main seal comes to mind.
I would lift the car off the ground enough to allow you to inspect the area in question. This is where having a lift really is a blessing. Wipe everything you can reach to get it as clean as possible ... then watch to see where your leak is coming from. To keep from wasting a lot of time laying under the car, having a good light source and a video camera that has an adjustable rate time-lapse mode aimed at where you think the leak may be coming from would be nice ... then you could review the 'footage' on your PC/laptop, etc. If not successful on the first go-around, you may need to move the camera around to record different areas, or at different angles, to really nail down the actual source. Good luck |
flyer86d |
Dec 25 2018, 08:36 PM
Member Group: Members Posts: 425 Joined: 12-January 11 From: Corea, Maine Member No.: 12,585 Region Association: North East States |
I think that if the oil return tubes were the source, they would leak onto the heat exchangers. I have seen 911’s wet sump past the pulley end crankshaft seal. I have had good luck with the dealer supplied oil filter with the correct check valve not wet sumping.
Charlie |
euro911 |
Dec 25 2018, 10:33 PM
Another place to check would be the oil cooler seals. One of my old 911s developed a bad leak from there, but it was pretty much while the engine was running.
rudedude |
Dec 26 2018, 01:54 PM
Senior Member Group: Members Posts: 508 Joined: 1-January 05 From: minneapolis, mn Member No.: 3,387 Region Association: Upper MidWest |
Valve cover? There is an anti siphon valve made to prevent tank from draining but I've never had an issue with my sixes doing what your describing.
fixer34 |
Dec 26 2018, 04:50 PM
Thanks all. I'll poke around some more and see if I can spot something.
Lift? Yeah, it would be nice, but I'll settle for a heated garage right now... |
fixer34 |
Dec 26 2018, 04:51 PM
rudedude |
Dec 26 2018, 08:05 PM
Lo-Fi Version | Time is now: 12th May 2024 - 10:14 PM |
