REAR SWAYBAR size question |
Marek |
Dec 26 2018, 03:58 PM
Newbie Group: Members Posts: 20 Joined: 27-April 15 From: Copenhagen , Denmark Member No.: 18,672 Region Association: None |
Hi Guys
Hope you all had a nice christmas hollyday I am in the Final stage of the Rear swaybar reproduction which I will have ready in a good few weeks I am making the set complete in 16mm and 18mm and to OEM specs ( rubbers and bushing will be OEM Porsche ) the kit will come complete , we are at 350-420 Euro range for a full kit , parts will be sold seperate also, also I made a plate so you dont need to weld the brackets on , more info will follow BUT My question is straight forward what would you put on 16, 18 , or do I also make a 20 mm Marek Attached thumbnail(s) |
dr914@autoatlanta.com |
Dec 26 2018, 04:08 PM
914 Guru Group: Members Posts: 7,864 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
15 front 16 rear for the four cylinder, 16 front 15 rear for the six cylinder
TravisNeff |
Dec 26 2018, 04:31 PM
914 Guru Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region |
I didn't think the sixes came with sway bars, just the fours starting in 73??
I would be interested in the larger bar for sure, the 20mm sounds interesting. From a swaybar calculator; I think the stock 16mm bar is only good for about 43lbs of spring force. I guessed on the bar length and arm length to plug in the calculator. Can you share the dimensions of the bar? (width and lever arm length). we could figure out what the rate is pretty easily. My guess was 36 inches wide, 14 inch lever arm length, take away 4 inches for the position of end links in relation to the centerline of the axle. |
914forme |
Dec 26 2018, 04:55 PM
Times a wastin', get wrenchin'! Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None |
Nice looking parts (IMG:style_emoticons/default/drooley.gif)
20mm or even larger, but you need to run a true limited slip differential if you want to keep forward momentum, as one of the rear will lift in hard cornering. If running open or torque biased I would leave it off. A flat cornering car does not it is mean a fast cornering car. |
Rand |
Dec 26 2018, 05:05 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
Is this an originality thing? Most don't run rear sways, not even the AXers. Always learning.
TravisNeff |
Dec 26 2018, 05:12 PM
I am interested in not running a 250lb rear spring. I want to move to softer springs and big sway bars
rgalla9146 |
Dec 26 2018, 05:30 PM
Advanced Member Group: Members Posts: 4,554 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
SirAndy |
Dec 26 2018, 07:53 PM
Resident German Group: Admin Posts: 41,640 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Is this an originality thing? Most don't run rear sways, not even the AXers. Always learning. Guess i'm not most people then ... (IMG:style_emoticons/default/confused24.gif) As for the OP, i'd like to see some adjustable drop-links for the stock rear bars! And yes, a 20mm option would be nice too. (IMG:style_emoticons/default/driving.gif) |
gandalf_025 |
Dec 26 2018, 08:16 PM
Senior Member Group: Members Posts: 1,453 Joined: 25-June 09 From: North Shore, Massachusetts Member No.: 10,509 Region Association: North East States |
I have aftermarket front and rear bars on my 6.
I bought them around 1974 from a local guy. Think it was H+H Specialties I’ll post the sizes when I get out to my freezing cold Garage tomorrow morning... |
914forme |
Dec 26 2018, 08:26 PM
That would have been H & H, and they made some nice stuff
And Andy I remember seeing someone made an adjustable rear drop link. It only had one threaded end so you had to pop them, adjust, re-install. But once done how often do you adjust them afterwards? |
gandalf_025 |
Dec 26 2018, 08:30 PM
H&H Specialties was based out of Chelmsford Massachusetts, a few towns away from where I grew up. I picked the front and rear bars up
from the guys house in Chelmsford.. |
ConeDodger |
Dec 26 2018, 08:54 PM
Apex killer! Group: Members Posts: 23,588 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
I run a rear bar with 200# Springs. With a rear bar, you have to be aware of the that moment where you go into a spin and stay just this side of it. I like the car with a rear bar. I wouldn’t go larger than the stock rear bar I have though...
914 Ranch |
Dec 27 2018, 01:38 AM
Team Sharp where the 914 grow wings Group: Members Posts: 1,411 Joined: 29-January 16 From: TheNorth Shore Retreat. Deland Member No.: 19,611 Region Association: South East States |
180 springs and a rear bar planted Carerror's ass. The front is still has a little under steer. She is Quaffed. The bar is 16 mm.
TravisNeff |
Dec 27 2018, 07:18 AM
180 springs and a rear bar planted Carerror's ass. The front is still has a little under steer. She is Quaffed. The bar is 16 mm. How misleading! Your car only weighs 180 lbs (IMG:style_emoticons/default/poke.gif) |
ConeDodger |
Dec 27 2018, 07:31 AM
Marek, what happened to the GT kit for fuel fill?
sixnotfour |
Dec 27 2018, 07:37 AM
914 Wizard Group: Members Posts: 10,432 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Marek, what happened to the GT kit for fuel fill? http://www.914world.com/bbs2/index.php?sho...=334114&hl= |
ConeDodger |
Dec 27 2018, 07:44 AM
Marek, what happened to the GT kit for fuel fill? http://www.914world.com/bbs2/index.php?sho...=334114&hl= Thanks Jeff! (IMG:style_emoticons/default/biggrin.gif) |
TravisNeff |
Dec 27 2018, 08:26 AM
Does someone have a rear bar laying around and be able to take two measurements for me? I need the length of the lever arm and the width of the bar
Attached image(s) |
gandalf_025 |
Dec 27 2018, 11:04 AM
I just went out to my very cold garage and measured the
H+H rear bar in my car... If you are looking for a factory bar, I can't help. But the H+H is 16mm, 38" long and the arms stick out 12". |
gandalf_025 |
Dec 27 2018, 11:18 AM
Lo-Fi Version | Time is now: 17th May 2024 - 04:55 PM |
