Sensor?, Unknown |
Sensor?, Unknown |
RolinkHaus |
Jan 3 2019, 04:00 AM
Member Group: Members Posts: 253 Joined: 21-July 18 From: Noblesville, IN Member No.: 22,330 Region Association: None |
What is this sensor? (IMG:style_emoticons/default/headbang.gif) I have a California 76 2.0, if that helps. I thought it may have something to do with the EGR, which has been deleted.
914Sixer |
Jan 3 2019, 06:49 AM
Fuel over run (cut off) sensor, not sure what it really does though.
ClayPerrine |
Jan 3 2019, 07:23 AM
Life's been good to me so far..... Group: Admin Posts: 15,459 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Early 914 2.0L cars used a rev limiting rotor. That cut the spark when you hit redline. Problem is, when you cut the spark, you don't cut the fuel that is being injected into the engine. That is bad for a car with a catalytic converter, as in Chernobyl style melt down of the catalyst. So the 75 and 76 cars got a fuel cutoff box in the fuel injection. This acted as a rev limiter, and didn't cause a meltdown of the cat.
dr914@autoatlanta.com |
Jan 3 2019, 08:51 AM
914 Guru Group: Members Posts: 7,853 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
very good explanation Clay.
Early 914 2.0L cars used a rev limiting rotor. That cut the spark when you hit redline. Problem is, when you cut the spark, you don't cut the fuel that is being injected into the engine. That is bad for a car with a catalytic converter, as in Chernobyl style melt down of the catalyst. So the 75 and 76 cars got a fuel cutoff box in the fuel injection. This acted as a rev limiter, and didn't cause a meltdown of the cat. |
Jan 3 2019, 08:53 AM
the good thing is that you have a California car so it is probably totally rust free! Congrats
Lo-Fi Version | Time is now: 14th May 2024 - 05:54 AM |
