SOT: 944 questions |
Rob-O |
Jan 5 2019, 12:42 PM
Senior Member Group: Members Posts: 1,252 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
Thought I’d ask here because I know that like me many of us own other P-cars besides our 914’s. I’ve posted this to Rennlist but it doesn’t seem like there are a ton of members in the 944 forum and it usually takes awhile to get replies, if you get them at all.
Bear with me as I get as much info as I can in this post. ‘86 944 Turbo, definitely a project. I’ve had it running and driving recently for quick shake downs. Car wouldn’t turn over so replaced the starter. Got it started. Quick drive showed it wasn’t charging. Replaced the alternator. Again started and drove it but still not charging. Now starting is erratic. I can hear the starter spinning but it isn’t pushing out the pinion gear and engaging the flywheel ring gear. While installing the starter and alternator the wiring looked fine at those connections. However, much of the cabling from the battery the sheathing of the cables are cracked and flaking off. There is a ground connection on the bellhousing but I haven’t had a chance to get a good look at it (some heater hoses in the way that will need to be removed). First question is if the starter is faulty. It’s a Bosch rebuilt but my thinking is that if it’s spinning it’s getting power. The pinion gear not engaging sounds like a problem internal to the starter. Second question is the alternator. If I’ve had the car running with this starter and still not charging than I feel like I’m dealing with separate issues. The starter issue (since it worked when I first installed it) and the alternator, where the old one didn’t work and the new one didn’t work. Maybe wiring but I can’t really imagine much else in this relatively simple circuit. Am I on the right path or could I be overlooking something? |
slivel |
Jan 5 2019, 01:29 PM
Old car....... older driver Group: Members Posts: 508 Joined: 10-July 04 From: San Diego Member No.: 2,332 Region Association: Southern California |
Another comment about 951's:
Addressing three areas will help your wallet and your sanity, Vacuum and pressure leaks in the intake tract. Exhaust leaks and wastegate malfunction. Electrical gremlins from aging wire and cables and their connections. Take care of these three areas first and save yourself many headaches and much expense. Good luck, Steve |
Lo-Fi Version | Time is now: 15th May 2024 - 09:41 AM |
