SOT: 944 questions |
Rob-O |
Jan 5 2019, 12:42 PM
Senior Member Group: Members Posts: 1,252 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
Thought I’d ask here because I know that like me many of us own other P-cars besides our 914’s. I’ve posted this to Rennlist but it doesn’t seem like there are a ton of members in the 944 forum and it usually takes awhile to get replies, if you get them at all.
Bear with me as I get as much info as I can in this post. ‘86 944 Turbo, definitely a project. I’ve had it running and driving recently for quick shake downs. Car wouldn’t turn over so replaced the starter. Got it started. Quick drive showed it wasn’t charging. Replaced the alternator. Again started and drove it but still not charging. Now starting is erratic. I can hear the starter spinning but it isn’t pushing out the pinion gear and engaging the flywheel ring gear. While installing the starter and alternator the wiring looked fine at those connections. However, much of the cabling from the battery the sheathing of the cables are cracked and flaking off. There is a ground connection on the bellhousing but I haven’t had a chance to get a good look at it (some heater hoses in the way that will need to be removed). First question is if the starter is faulty. It’s a Bosch rebuilt but my thinking is that if it’s spinning it’s getting power. The pinion gear not engaging sounds like a problem internal to the starter. Second question is the alternator. If I’ve had the car running with this starter and still not charging than I feel like I’m dealing with separate issues. The starter issue (since it worked when I first installed it) and the alternator, where the old one didn’t work and the new one didn’t work. Maybe wiring but I can’t really imagine much else in this relatively simple circuit. Am I on the right path or could I be overlooking something? |
Rob-O |
Jan 9 2019, 08:20 PM
Just wanted to circle back and close this up. George I thought it unlikely that it was two items going bad. The starter was turning but not engaging so I got a replacement. Before hooking up starter #2 it occurred to me that when installing starter #1 I merely unhooked the wires on the back of the original starter and placed them in the same spot on the starter #1. I think I even took a picture to ensure I would put them in the locations I found them. Before hooking up starter #2 it occurred to me that they might not be on the correct studs (and hence not completing the circuit for the alternator to charge). Sure enough a quick search showed both large wires on the same stud (and that makes perfect sense of course). I hooked them up that way when I installed starter #2. Car started right up AND the alternator is now charging. Which makes sense.
I should’ve checked the wiring while installing the first starter. In my defense this was a project car and the guy I bought it from was clueless about cars, only saying that he ‘had a guy come over to get it running’. When I first saw the car it was indeed running and starting. Even after I installed the first starter it started. But I’m sure it didn’t like that fat cable being hooked up incorrectly... |
Lo-Fi Version | Time is now: 15th May 2024 - 01:38 AM |
