Machining tolerances for boring out Mahle cylinders to 96mm |
seanpaulmc |
Jan 7 2019, 08:21 PM
Member Group: Members Posts: 303 Joined: 6-December 16 From: Orlando, FL Member No.: 20,649 Region Association: South East States |
Looking to get a set of original 94mm Mahle 2.0L cylinders bored out to 96mm. What are the recommended tolerances for giving to the machine shop for this diameter?
Thank you, Sean |
Mark Henry |
Jan 8 2019, 08:42 AM
The machine shop needs a torque plate to do the job, if they have to make one it will cost more than new jugs from EMW.
I build engines in Canada, we Canadians are cheap asses so I was going to make a torque plate, but with new jugs from EMW it's just not worth it. |
wndsrfr |
Jan 8 2019, 09:25 AM
Senior Member Group: Members Posts: 1,430 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
The machine shop needs a torque plate to do the job, if they have to make one it will cost more than new jugs from EMW. I build engines in Canada, we Canadians are cheap asses so I was going to make a torque plate, but with new jugs from EMW it's just not worth it. Find a shop that handles motorcycle work....they'll likely have the torque plate and be familiar with aircooled jugs... |
Mark Henry |
Jan 8 2019, 01:29 PM
The machine shop needs a torque plate to do the job, if they have to make one it will cost more than new jugs from EMW. I build engines in Canada, we Canadians are cheap asses so I was going to make a torque plate, but with new jugs from EMW it's just not worth it. Find a shop that handles motorcycle work....they'll likely have the torque plate and be familiar with aircooled jugs... Not worth it, I'm cheap so I have looked into local, but loss of my time alone would kill any savings. YMMV. |
Lo-Fi Version | Time is now: 24th May 2024 - 11:25 AM |
